I converted a MKV file to AVI using MenCode, but the subtitle was not in the final AVI file. I then tried to convert the same MKV file to AVI by using VirtualDubMod, and the output AVI file also lacks subtitles. I am not sure exactly what steps I should take to include subtitles in the final AVI file, i.e. which compression mode and the different options.
Thread: subtitle in a MKV file
I am looking for solution for this problem too.
I tried WINAVI 7.5, its does not work for MKV subtitles.
I only tried successfully with GraphEdit, but the AVI Renderer I used does not support Xvid.
GraphEdit too tedious to work on, since i can only configured it to handle one file at a time.
The other solution i tried is to extract the subtitle out using VirtualDubMod, then I use WinAVI to encode the AVIs + individual subs in batch task.
Still looking for a one-app-does-all approach.
How can I pull out an embeded subtitle from *.mkv file?
By si_asad in forum SubtitleReplies: 4Last Post: 31st Aug 2011, 13:48 -
how to add a subtitle track file to an mkv file???
By Sh@DY in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 19:57 -
How to add subtitle into a MKV file
By c1steady in forum SubtitleReplies: 2Last Post: 13th Nov 2009, 01:15 -
how to split mkv file and subtitle file to play on blu ray via hdd usb
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 11:28 -
extract subtitle from mkv file
By py52126 in forum SubtitleReplies: 1Last Post: 4th Feb 2009, 17:01
Statistics
Newest guides
Latest tool updates
New media comments
