Or am I copying my double layer discs wrong?
They play fine on the computer but won't play on my Pioneer Elite 59avi
+R DL or -R DL? It DOES make a difference. My player is certainly not high end, but my Philips DVP-642 has minor problems with all -R DL discs but it plays +R DL flawlessly. I also recommend only using Verbatim DL discs, whether you burn +R or -R. You're asking for problems if you use anyone else's.
maybe I'm just burning my discs wrong?
I've been using AnyDVD in the background and ripping using Nero Recode.
Is there a better solution?
also I've been using the Verbatim discs
Try DVDDecrypter: ISO Read>ISO Write. Very simple.
It works if you rip the DVD into a ISO file instead of the file method in DVD Decrypter and then use IMGBURN to write to the DL disc
Thanks for the help guys
Pioneer BDR 205 won't play BDMV video discs
By kurbads in forum Blu-ray RippingReplies: 4Last Post: 30th Jan 2012, 03:39 -
used Multi-AVCHD, discs won't play in the Insignia WBRDVD player- WHY?
By Sinatrafan in forum Authoring (Blu-ray)Replies: 25Last Post: 19th Apr 2010, 07:23 -
Combined 2 discs into one, but disc won't play on dvd-player...
By StrobeLightEpileptic in forum Authoring (DVD)Replies: 5Last Post: 7th May 2009, 21:24 -
Verbatim DVDs with very high PI error/failure rates at the end of discs
By inoueto in forum MediaReplies: 10Last Post: 6th Mar 2009, 17:12 -
My player won't play burned discs anymore.
By uNderdog_101 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 30th Dec 2007, 16:44
