Hi guys/gals....
When I try to convert my vob I made from DVDDecrypter (no file splitting), VOB2MPG just goes from 0 - 100% in a second and displays "Finished processing 1 vobset" ...
here is the log...
I have used vob2mpg in the past and it works amazingly, and I havent changed any of the settings on DVDdecrypter so I'm at a loss here...
Any ideas?
Thanks..
file=C:\SOMETHING_NEW\VIDEO_TS\VTS_01_1.VOB
FormatName=mpeg
Num_Frames=179812
DurationInSecs=5999
Duration=01:39:59.7
VideoCodec=mpeg2video
Width=720
Height=480
Standard=NTSC
BitRate=5346
AudioStreamCount=1
Audio1StreamID=[0x80]
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
************************ END ************************
23:03:27: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
23:03:27: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
23:03:27: libavutil version: 49.0.0
23:03:27: libavcodec version: 51.4.0
23:03:27: libavformat version: 50.2.1
23:03:27: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
23:03:27: Input #0, mpeg, from 'multi:C:\SOMETHING_NEW\VIDEO_TS\VTS_01_1.VOB*':
23:03:27: Duration: N/A, bitrate: N/A
23:03:27: Stream #0.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9800 kb/s
23:03:27: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
23:03:27: Assuming NTSC for target.
23:03:27: Output #0, dvd, to 'C:\SOMETHING_NEW\VIDEO_TS\VTS_01.mpg':
23:03:27: Stream #0.0, 29.97 fps(c): Video: mpeg2video, yuv420p, 720x480, q=2-31, 9800 kb/s
23:03:27: Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
23:03:27: Stream mapping:
23:03:27: Stream #0.0 -> #0.0
23:03:27: Stream #0.1 -> #0.1
23:03:27: frame= 0 q=-1.0 Lsize= 0kB time=10000000000.0 bitrate= 0.0kbits/s
23:03:27: video:0kB audio:0kB global headers:0kB muxing overhead -1.#IND00%
********************** Output Folder *******************
23:03:27: Volume in drive C has no label.
23:03:27: Volume Serial Number is E81A-DD5D
23:03:27: Directory of C:\SOMETHING_NEW\VIDEO_TS
23:03:27: 29/04/2006 23:03 <DIR> .
23:03:27: 29/04/2006 23:03 <DIR> ..
23:03:27: 29/04/2006 23:03 0 VTS_01.mpg
23:03:27: 29/04/2006 22:55 4,009,644,032 VTS_01_1.VOB
23:03:27: 2 File(s) 4,009,644,032 bytes
23:03:27: 2 Dir(s) 30,079,737,856 bytes free
23:03:27: C:\SOMETHING_NEW\VIDEO_TS>
Thread: VOB2MPG Problem
You may get better assistance in this thread:
http://forum.videohelp.com/viewtopic.php?t=252033
Or at worst, in the SVCD2DVD General forum, as the moderator for that forum is the author of VOB2MPG.
Post a request to move the thread in this thread:
http://forum.videohelp.com/viewtopic.php?t=119319If in doubt, Google it.
Just seen this: Is this still a problem?
No, for some odd reason it work again, lol.
Cheers for the great little program... something wierd going on though
vob2mpg first run problem
By klex in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Apr 2012, 22:58 -
problem with VOB2MPG
By Onceler2 in forum Video ConversionReplies: 3Last Post: 16th Sep 2011, 13:12 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
vob2mpg problem
By branjk in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Oct 2009, 02:14 -
VOB2MPG v2.5 language problem
By akqz in forum DVD RippingReplies: 1Last Post: 8th Aug 2007, 11:27
Statistics
Newest guides
Latest tool updates
New media comments
