Does anyone know of a way to speed up the initialization process of DVD-RW Drives?
I have 2 optical drives - A LiteOn DVD-Rom and a NEC DVD-RW.
When I put a disc in the LiteOn, the access LED goes on for about 2 seconds, and the DVD is then available to the OS, viewable in "My Computer", etc...
However, with the NEC, when I insert a new DVD, the access LED is on for a full 11 seconds before the disc finally becomes available to the OS.
Obviously, these access times make a big difference when you are cataloging a large disc collection, and if you try to access the disc before it is ready (i.e., before the LED goes out after the initial insertion), then it seems like it takes even longer to become ready.
Does anyone know what controls this behavior? Could 3rd party softwares that alter DVD behavior (like DVDIdle) be useful? Can anyone suggest a fix? I have the NEC-3540A and have flashed the firmware to the latest version.
I think that is just a quirk of the newer generation NEC burners. My 3550a does that and it can be annoying. I am not aware of a fix.
seek time and time it takes for the tray to open and close can't be changed. NEC is slow in this dept. I would not buy another one, I had thought unofficial firmware would be much better, it is not much better only in single layer it rips faster. Many drives use Phillips chip one might as well buy BenQ , I never had one but never heard any complaints in this forum either.
DVD skipping problem. Slow drive speed.
By rayden54 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Jan 2010, 15:37 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 04:18 -
PC drive does not recognize DVD-Video disc
By niko84 in forum Software PlayingReplies: 4Last Post: 17th Sep 2007, 19:44 -
Slow DVD drive (LG GSA-H42N) problems
By cosmo09 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Sep 2007, 00:51 -
Sony DRU-820A DVD Drive suddenly burning slow
By progrocktv in forum DVD & Blu-ray WritersReplies: 3Last Post: 24th May 2007, 21:55
Statistics
Newest guides
Latest tool updates
New media comments
