Hi everyone, I tried this once and it didnt work. I have a pretty recent RCA stand alone dvd Recorder. I would like to transfer video files on my pc to a dvd recordable using the dvd recorder. I have an ATI 9200 128 meg vid card with video out and I have the converter for my audio from my pc to RCA audio cables to go to the DVD recorder. How would I record? I appreciate any help you guys and girls can give me. Thanks.
Hi- if I understand your question right, look at it this way...
the computer is your video source, just like a camcorder or VCR; so check into its output config: are you actually sending video out? you can check this with a VCR just as well as with a DVD recorder, you might have options that need to be set differently. Some cards output A/V, S-video, and RF (ch3-4) in 2 flavors- NTSC & PAL (you can use both on many DVD recorders). You can also check your outputs with a component TV.
If you are getting good output, then check for the 'usual suspects': bad cables, misconnected cables, and copy-protected files.
The RCA DVD recorder will act just like a VCR as far as inputs- you can get in thru the tuner, the A/V plugs, S-video, mebbe also DV in & optical, so you have to set your input type. Again you can experiment with a VCR, camcorder, digital camera- any other source substituted to narrow the problem.
hope this gets you going!
How you can use a stand alone DVD recorder and your Canopus 110
By fuzzblaster in forum CapturingReplies: 22Last Post: 3rd Oct 2010, 12:06 -
Stand Alone DVD record Won't Play on PC?
By rkersh409 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 26th Jan 2010, 12:23 -
Typical lifespan for a stand-alone DVD recorder.
By usually_quiet in forum DVD & Blu-ray RecordersReplies: 114Last Post: 27th Nov 2008, 21:21 -
converting to AVI or mp4 with stand alond dvd recorder..speed test
By diablo_ogre in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2008, 09:55 -
Looking for a Stand alone, cheap, DVD recorder, timecode on screen.
By AtomX in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Feb 2008, 16:10
Statistics
Newest guides
Latest tool updates
New media comments
