Heya all...how do I do that? The append option is greyed out?? I want to combine 2 mpg files together...
Thread: Append 2 mpg in virtualdub?
If I am not wrong, Virtualdub does not output MPEG format. You need to frameserve to a MPEG encoder. You can use MPEG VCR to join MPEG files. It does streaming so the quality is same as original.
You're not wrong - VirtualDub doesn't support any MPEGs in any way. However...Originally Posted by pchan
Before you try frameserving, try appending in either of Virtualdub-MPEG2 or VirtualDubMod.Originally Posted by pchan
Failing that, download TMPGEnc (the free / trial version) and use the File -> MPEG Tools... -> Simple Multiplex utility.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Yes... free MPEG tool !Originally Posted by daamon
Hmm...I have TMPGenc...but what does the simple multiplex utility do? And actually, what am i using it for? Merging the two files?
It has MPEG Tool where you can merge MPEG files.
Please refer to this for the Merge and Cut....
http://www.digitalfaq.com/dvdguides/...ls.htm#tmpgenc
[Resolved] Making 2 AVIs the same so that VirtualDub can append?
By Diana (Cda) in forum DVD RippingReplies: 32Last Post: 9th Dec 2010, 14:01 -
Avisynth: Append mpg script ?
By zzyzx2 in forum EditingReplies: 4Last Post: 8th May 2010, 16:26 -
virtualdub append question
By thecrock in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2008, 10:30 -
Cannot append some AVI files in VirtualDub.
By StehpenRH in forum EditingReplies: 3Last Post: 8th Oct 2008, 04:51 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 18:00
Btw,
That's a pity... no audio comes out.
