Hi all..
I would like to solve this problem..
Whenever I play the LOTR DVDs..they subs automatically will enable itself with danish subs..
I would like it to start with English subs..
Is there any way to change it?
Thanks!
Thread: Subtitle problems..
Not without remastering it (i.e. pull it to the HD, rewrite the IFO file, then burn another DVD)
Thanks for the reply..
Is there any guide about how to rewrite an IFO file?
Hi-
http://www.videohelp.com/~r0lZ/pgced..._new_macro.htmThis method allows you to jump to any menu or title on insertion of your DVD, setting the audio and subtitle streams of your choice and by-passing anything in your way (e.g. annoying FBI warnings, studio promos and Dolby Digital trailers) and having all the DVDs internal registers set exactly as they would be if the commands followed the original path
Subtitle problems using convertxtodvd
By gtorres001 in forum Authoring (DVD)Replies: 41Last Post: 3rd Mar 2012, 01:36 -
Subtitle problems
By Mrs Cee in forum Newbie / General discussionsReplies: 7Last Post: 8th Sep 2010, 18:09 -
Problems with Subtitle Workshop
By Maurob67 in forum SubtitleReplies: 2Last Post: 7th Jun 2010, 02:42 -
Subtitle problems
By neroman00 in forum SubtitleReplies: 1Last Post: 30th Dec 2009, 03:15 -
Subtitle problems
By artistguy68 in forum ffmpegX general discussionReplies: 6Last Post: 27th Jan 2008, 19:40
Statistics
Newest guides
Latest tool updates
New media comments
