VideoHelp.com Forum
    Frame sizes in pixels (for 1.25 and 16:9)PAL 720x576, 25 fps (frames per second)NTSC 720x480, 30/29.97 fps
    PAL Video size (square pixels): 1.25 (720x576) and 16:9 (1280x576)NTSC Video size (square pixels): 1.25 (600x480) and 16:9 (1013x480
    What does above trying to indicate? I thought 4:3 digital NTSC has 0.9091 pixel aspect ratio at 720x480?
  2. Member edDV's Avatar
    http://www.kiva.org/about
  3. Член BJ_M's Avatar
    720/576 = 1.25
    600/480 = 1.25
    both of the above are correct for 5:4 ratio monitors and 1280 by 1024 pixels, and 1600 by 1280 pixels ratio panels ...
    If DVPro is 1.25 in aspect ratio whereas NTSC is 1.333. Wouldn't the image become stretched or cropped when captured to PC?
  5. Член BJ_M's Avatar
    Standard TV has a 4:3 aspect ratio, not NTSC .. but "standard tv" these days often more and more means wide screen and 5:4 aspect ratios ... or 4:3 aspect ratio ..
    in other words - being ntsc doesnt mean it has to be 4:3 BUT if it is ITU-R BT.601 (also known as "CCIR-601" or "Rec.601"), and that requires a horizontal sampling rate of 13.5 MHz and an active line of 720 samples, then the pixel aspect ratio for 525-line video (NTSC) is 10:11. The pixel aspect ratio for 625-line video (PAL) is 59:54
    but -- square pixels even then are not really square ! They have an aspect ratio of 768:767, which is very close to 1:1, but which is not truly exactly 1:1
    Why is it only 600x480 square pixels? If I'm capturing from standard 4:3 NTSC TV cannot I have 640x480 square pixels displayed on my PC screen?
  1. Are there different versions of the MainConcept H.264 Video codec ?
    By Bansaw in forum Newbie / General discussions
    Last Post: 16th Feb 2012, 11:00
  2. Replies: 11
    Last Post: 20th May 2011, 22:59
  3. MXF with JPEG2000 codec in Mainconcept Reference
    By lord25 in forum Video Conversion
    Last Post: 3rd Nov 2009, 09:34
  4. Mainconcept DV Codec in VirtualDubMod
    By WinSpirit in forum Newbie / General discussions
    Last Post: 14th Dec 2007, 23:31
  5. Mainconcept DV Codec Vs. The Rest
    By SeeNoEVO in forum Video Conversion
    Last Post: 5th Jun 2007, 08:16
