Hi,I found this Free Syntax Olevia LT32HV 32" LCD TV on the websites.
How about the Syntax TV? Compare to Toshiba or ViewSonic?
i'm totally new to LCD TV so any suggestion in basic terms would be appreciated.
http://secure.syntaxgroups.com/produ...jsp?pid=LT32HV
Might make an OK monitor, but I wouldn't buy one as a TV. Low contrast ratio, no HDMI (although it does have DVI in). It is their old model, hence it being given away.
Get the LT32HVX, its there newest model. The older 27" isn't true 16:9 either.
Newer models have HDMI-DVI that supports HDCP or whatever that is. Its important to HT tech nuts.
You'll get a great picture period. The better the content the better the picture. Sure a CTR will still do better overall on SD content, but its not that much of a downgrade at all. Make sure your cable signal is strong and use a good S-video cable and you have a pretty darn good picture.A. Thomas - Project Digital Underway: Eliminate All Physical Media (LP's, VHS, DVD, CD), Compress All DVR-MS/WTV files and Convert PAL VHS to DVD or Digital File (H.264?)
That was just a prize give away. Now its changed to another prize.
he is a supermediastore.com spammer
Originally Posted by dj4monie
I'm looking for a TV and its a very hard to choose.do you think the HP Pavilion LC2600N 26" better,or LT32HVX ?
http://www.amazon.com/gp/product/B00...Fencoding=UTF8
HD camera for recording small LCD screens + "normal" use?
By sincostan45 in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 15th Mar 2010, 00:08 -
ffmpegX won't convert files due to "syntax error near unexpected token"
By JayEm in forum ffmpegX general discussionReplies: 1Last Post: 15th Feb 2010, 17:26 -
"if" syntax error
By njitram2000 in forum Authoring (DVD)Replies: 2Last Post: 8th Nov 2009, 11:30 -
Olevia 227V 27 "
By zukie23 in forum DVB / HDTVReplies: 1Last Post: 4th Dec 2007, 01:48 -
Attempting to Fix Blurry Picture on Olevia 232V 32"
By bjorgens in forum DVB / HDTVReplies: 15Last Post: 31st Jul 2007, 16:05
Hi,I found this
