i tried using HC Encoder with DVD Rebuilder, but the output video was all messed up. the best way i can describe it is it looks like when you fastforward a VHS tape with a crappy VCR, the picture goes all wavy. or if the vcr cannot track the video very well, the image goes all messed up. its so bad that i cant make out any of the picture at all.
any ideas?
heres a pic of the preview window of HC Encoder. the output looks the same too.
If you are positive the source is good,then i would re-install DVD-Rebuilder as it looks like the something could be wrong with the AVISynth installation or something along those lines.
Tom
it was avisynth! i was using version 2.57 alpha. i decided to go all the way back to 2.55 just incase, and its fine now. are there any benefits in the newer versions of avisynth?
thanks for the help.
No problem. JDobbs would be better to answer the questions on the AVISynth. I use the Pro version and i always jsut use the installer to allow it to install the versions that he deems best to work with his program. I figure its safest like that LOL
Tom
Anyone ever use a transcoder on DVD-Rebuilder output?
By sldvd in forum EditingReplies: 2Last Post: 20th May 2010, 13:16 -
BD Rebuilder 1080 output
By HARRYSPADGE in forum Blu-ray RippingReplies: 8Last Post: 19th Dec 2009, 21:26 -
output resolution xilisoft video encoder
By KlintIstwood in forum Blu-ray RippingReplies: 2Last Post: 20th Dec 2008, 12:29 -
How to upgrade HC Encoder in DVD Rebuilder?
By julitomg in forum DVD RippingReplies: 3Last Post: 30th Dec 2007, 08:31 -
Wich freeware encoder is best with DVD Rebuilder?
By julitomg in forum DVD RippingReplies: 12Last Post: 21st Oct 2007, 22:10
