Hello lads,
I need to make a DVD from 3 or 4 .avi (episodes from LOST season 2) with AC3 audio and add the subtitle track for each episode.
DVDSP does not recognize the subtitles.
Is there any other way to make this?
Thanks in advance,
Manolo.
"IE 7 and Vista remind me of the old definition of a giraffe: it's a horse designed by a committee."
Manolo,
I believe I covered this in the forum.
STF for Subtitler.
You will need that to convert the .srt to DVDSP compatible
.stl files.
I also have talked about how to apply them.
as for the avi, use MPEGStreamclip to convert the
.avi to DV Stream, then use Compressor
( AND A BIT RATE CALC) to make your mpeg-2 file and aiff.
Compressor ( at least IMHEwith v 1.1) sometimes
crashes on divx encoded .avi files, so that's why
my reccommendation .avi->dv stream->compressor.
( you can also use QT Pro 7 to go .avi -> Mpeg-2).
oh heck, because its Easter....
Forum Search
again"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Thanks for the extraordinary fast replies.
Thanks fellows,
M.
Another very simple (maybe the directest) way to get a DVD from several .avi + .str files with simple menus & togglable subtitles is to use the (freeware) Moviegate 2.0.
How to make DVD with Video .avi and Subtitle .srt?
By lukanino in forum Newbie / General discussionsReplies: 3Last Post: 10th Apr 2012, 13:51 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
What am I doing wrong? AVI to DVD with srt subtitles.
By du2vye in forum ffmpegX general discussionReplies: 8Last Post: 21st Oct 2009, 12:54 -
Question how to make srt/avi subtitles bigger when playing in DVD player
By jimdagys in forum SubtitleReplies: 6Last Post: 24th Oct 2008, 00:10 -
DVD to *.avi rips with *.srt subtitles
By WhiteFox in forum Video ConversionReplies: 0Last Post: 3rd Sep 2008, 10:51
