VideoHelp.com Forum
Results 1 to 12 of 12
    Best remote? Suggestions?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    What MCE video card are you using? If Hauppauge, you can get a kit with card and the remote.
    I'm using hte Hauppauge 500. Just installed it. Now i'm on the hunt for my next piece of my media center which will be my remote. I appreciate any info on what to get. Thanks>!
  4. Member Treebeard's Avatar
    If your interface is Media Center then this is a must have remote
    http://www.zipzoomfly.com/jsp/Produc...uctCode=604651
    I use it w/ my MCE and works wonders. has learning button for TV power and VOL up/down learning button for receiver.
    What are the two included light things for that go wiht the inputs in the back fo the receiver for? I must be dumb...
  6. Mod Neophyte Super Moderator redwudz's Avatar
    Please don't post the same question in two threads. The two items you are probably talking about are the infrared receiver for your remote and a infrared transmitter for a VCR or other device.
    Okay sorry about that. How do I set up my tv with the remote? There was no documentation with this thing. I don't knwo why...
  8. Member Treebeard's Avatar
    here is the manual for it, you should have got one w/ your order.
    http://www.fivepowells.com/mce/MS%20Remote%20manual.pdf
    As an alternative to a remote control, check out Windows Media keyboard. It works with the WMCE receiver out of the box, works concurrently with the remote, and I think it is an easier TV controller.
    However, the little button on the keyboard that acts like a mouse needs work. It suppose to function like the red stick on IBM Thinkpads. It is not very responsive.
    Otherwise, this one wireless device replaces the remote, the keyboard, and the mouse, except as noted.
    There are other wireless keyboards brands that provide the same functions as the Microsoft product but I don't know much about them.
  10. Member mike909's Avatar
    To properly address this question, you need to decide if you want an IR remote or RF.
  11. Member Treebeard's Avatar
    the distance of RF sucks. IR or BLUETOOTH for media centers considering you will most likely be at least 8 feet from the receiver. I use the Media Remote for everything in Media Center which Im rarely not in. I do have an RF keyboard/mouse on my media center also. I used a 15ft usb extender to get the receiver close to the couch.
  12. Member mike909's Avatar
    RF sucks
    well...that's kind of relative. I use mine from the backyard to controll the volume of my Media center when playing music. For me...RF was a big necesity.
  1. Can't get MCE 2005 to recognize vBox 3560
    By frankmaster100 in forum Media Center PC / MediaCenters
    Last Post: 2nd Dec 2009, 08:11
  2. Hauppauge HVR-1600 HD tuner with MCE 2005
    By rallynavvie in forum Media Center PC / MediaCenters
    Last Post: 29th Mar 2008, 13:22
  3. Remotes dont work under MCE 2005
    By Annex in forum Media Center PC / MediaCenters
    Last Post: 12th Jun 2007, 07:30
  4. DVD/TV Decorder for MCE 2005 ?
    By Datahead in forum Newbie / General discussions
    Last Post: 5th May 2007, 12:03
  5. Decorder that works with MCE 2005?
    By Datahead in forum Media Center PC / MediaCenters
    Last Post: 5th May 2007, 11:57
