  1. Anybody know how to do videos with Quicktime for PSP? I've been trying to test it out but it's not working. I'm using MPEG-4 container with H.264. Bitrate for video is 100 (only for fast encode) and 128kbits with 44100hz for audio. I can't figure it out.
  2. I don't think it will work.
    QuickTime sucks for encoding videos.
    Anyway, using H.264, you should use a higher bitrate than 100kbps. thats probably a bitrate not even supported by the psp. Use 384kbps or something. And set the audio (AAC) for 48khz instead of 44.1khz.
    make sure the file is named MAQxxxxx.MP4 and goes in the 100ANV01 folder
    asdf
    Quicktime won't add the special "atom" to the video header that the PSP needs, so it's useless for PSP use.
    If you're on OSX you should try ffmpegx
    Windows: PSP Video 9
    Linux: PSPVC
    pspware is a good converter to get quicktime to with psp
  1. My XviD4PSP PSP video conversions are not supported on PSP
    By godfist314 in forum Portable Video
    Last Post: 18th Aug 2008, 10:59
  2. Vegas 6.0d - Export to PSP option without having the PSP connected?
    By bobogs in forum Newbie / General discussions
    Last Post: 16th Mar 2006, 10:14
  3. quicktime MOV to PSP/MP4 ?
    By iThinkYouBrokeIt in forum Video Conversion
    Last Post: 24th Jan 2006, 02:41
  4. PSP won't recognize my movie from ffmpegx PSP preset
    By drewson99 in forum ffmpegX general discussion
    Last Post: 31st Aug 2005, 13:18
  5. QuickTime DV movie to PSP encodes video too fast
    By tvalleau in forum Newbie / General discussions
    Last Post: 7th Jul 2005, 19:48
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
