i get an applescript error of "can't get text of item..." whenever i try to convert seemingly any kind of file to any other kind of file. there's no getting past this error. i found some posts regarding the error message, and i've tried everything with no success. can anyone help me, please?
Results 1 to 10 of 10
I recently downloaded this program (0.0.9x r2 )and I get the same error. Is there a fix?
I've seen that message when I've failed to fill in one of the required fields. Often this is the fps field (on the Video tab) that is left blank when ffmpegX can't determine the fps from the source video. You have to manually fill in what you want (or choose it from the popup).
The fps section is filled and I still get the script error. It seems like no matter what I do, the script error will always pop-up upon clicking "Encode."
I've tried previous versions to see if this is just a recent problem, but no such luck-- still get the same error.
Please post the entire error message.
"Can't get text item 2 of "LOCATIONOFTHEFILE.whatever". (-1728)Originally Posted by rumplestiltskin
Check if you have any spaces or other characters (other than a-z, A-Z, 0-9, or parens) anywhere in the pathnames to the app, target file, destination file, or binaries.
I checked, and don't have anything out of the ordinary.Originally Posted by rumplestiltskin
Here's a screen of how it's named.
(NOTE: Not according to this picture-- I also tried having the output resolution the exact same dimensions as the input dimensions, the same apple script error occurs. This goes for audio output also.)
I'm stumped. Perhaps major will have another suggestion.
I've been searching the net for a solution, and everywhere I go comes out as a dead end. Mostly because no one has solved this problem.
I've seen only one solution that involved something with the the language that you use on your system and its region. But, that solution only worked for that one person who had "Polish" as his set language, and switching it to English solved his problem.
Has anyone else here been 'zapped' by "text-enhance"
By DB83 in forum ComputerReplies: 45Last Post: 27th Oct 2011, 05:50 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
Trouble With "Timed Text"
By Startropic1 in forum Video ConversionReplies: 5Last Post: 31st May 2010, 15:28 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 20:50 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
