    I need some software that can replace audio in my short movies. Movies are in wmv format.
    Does someone knows some software. I have allready used Blaze Media Pro but this program isnt good. The quality of saved movie with new audio is bad. The program is also very slow.
    Doesn't WMM or WME come with a stream editor?
    If you want something that cover's almost everything in one package , grab ulead video studio se , version 9 in ebay for around $40.00au .
    Transition's , clipping , frame rate conversion (perfect) , audio editing , output in mov , wmv , avi , mpeg1/2 , dvd , dvd menu's ... and much more , not to forget , burn dvd project as well ... and dv recording plus share online .
    Accept's wmv's , go to share , click "create sound file" , choose compression type , frequency , and go .
    Support's audio output in wav , using various installed codec's , rm audio format , mpa for dvd (rename file extension to m2a , convert with besweet to ac3) , and wma .
    Also support's some feature's with audio stretching / shrinking (tricky to get perfect) .
    What it dosent cover :
    Motion menu's :
    Combine tool's - avisynth , bbmpeg , quenc , virtualdub , wax2 (accept's video framserved from virtualdub/mod) , gimp (to create png's with alpha's)
    Zs4 - various technique's such as blend's , specialized picture in picture movement .
    Super for mov and wmv conversion to other format , where it can be handled either by virtualdub or other .
    Blender for animation's as required for menu's , ect .... wax2 can load 3d model's as well ... currently working on this project type .
    Wings3d for creating your own 3d model's .
    Xroads - can convert between different 3d model format's .
    Audio wrap - if video is in avi , then use slide show movie maker ... can loop audio to fill video length , handy .
    Audiocity , and reaper for audio editing ... goldwave if you want to spend another $30.00au or so , but then you have the best audio editor you could ever have when it come's to re-aligning audio to video in the case of audio sync issue's .
    So for under $100.00au , plus a few freeware , you can do it all , and more
    For that price , it cut's down having alot of program's installed on the pc which can alway's lead to conflict's , or pc running slower than when it was new .
    Dvd burning :
    Imgetool burn
    Imageburn (dvd decrypter in disguise)
    Ghostburn (suppot's the creation of bootable iso's)
    Avs disc creator
    Xpcdburner
    Ulead video studio , of course
    Nero , for those that have it
    Puppy (a mini bootable linux distro) , handy when xp stuff's up , allow's the recovery of file's from hd to cd , go online , download update's , print info that might help ... burn's to both cd or dvd .... or use it for every day basic work (even include's a game like bubble pop , damn addictive ... no work got done for hour's here ... lol)
    At same time , grab a copy of insert security iso , and burn to cd ... it's a mini distro as like puppy , but contain's not only the ability to surf the web , but tool's to chech varoius hardware on the pc to test if all is working well ... dont believe what the hd tool's say from manufacturer's ... those tool's are complete crap ... use the linux hd testing tool ... it really thump's the drive ... then you get an acurate test .
    Note : Extremely versatile ... can rename account folder's in xp should it be ever the need to do so (I have done his twice , without problem's)
    The reason I did this was to rename the user id , and all associated folder's , and registry link's to the new owner ... , thus avoiding having to do a complete reinstall ...
    Do I know stuff or what ...
  1. How to combine video with audio file and replace audio with video files ?
    By designbuyers in forum Newbie / General discussions
    Last Post: 8th Feb 2009, 11:12
  2. Replace audio in MPG video
    By rdfarr in forum Authoring (DVD)
    Last Post: 29th Jan 2009, 17:22
  3. Freeware to replace audio track on a video file?
    By gastrof in forum Newbie / General discussions
    Last Post: 2nd Jun 2008, 21:54
  4. Newbie needs a Video Editing Software to Replace Windows Movie Maker
    By baxtermadux in forum Newbie / General discussions
    Last Post: 1st Apr 2007, 07:45
  5. Replies: 3
    Last Post: 15th Oct 2004, 14:51
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
