VideoHelp.com Forum
  1. Ave,
    I'm really new to the entire HDTV scene so i need some help. Here's my situation.
    I have a 52" HDTV with 1 Component Input & 1 DVI Input.
    I have a Time Warner HDTV Cable Box (Reciever) and a Panasonic Home Theater System (DVD Player)... both support Component & DVI Output.
    I already have a Acoustic Research Component Cable.
    I dont have a DVI cable, and need to buy one.
    My first Question is:
    A) Should i Connect my DVD Player to the HDTV using Component / Cable box to HDTV using DVI? Or the other way round? Or it doesn't matter? (Currently i have the DVD Player to HDTV using Component Cable).
    B) As i said, i need to buy a DVI Cable.. when i looked it up on the Internet, there were too many choices... i don't know the differences, i do understand i need a DVI-D cable to go into my HDTV... but i don't know if my Cable Box or DVD Player needs the same DVI-D or HDMI or something else to go into it's Socket for the output.
    C) In case i do need a DVI-D Dual Link Cable, can someone suggest an economical Price/Place to get it from?
    Thanks,
    Mickey
    I don't suffer from Chronic Insanity & Psychosomatic Multiple Personality Disorder!
    I enjoy every moment of it!
  2. Member edDV's Avatar
    Give us the model numbers of your HDTV and cable box (Scientific Atlanta 8300HD?).
    A. Usually DVD player (720x480p) component and HD cable box (1920x1080i) with DVI.
    B. Time Warner should provide you with either a component or DVI cable. You already paid for it.
    C. You need DVI-D single link. If you need to buy one try here.
    http://www.ramelectronics.net/html/D...or_cables.html
    http://www.kiva.org/about
  3. Ave,
    Thanks for your reply. Actually i didn't get a reply for quite a while and did quite a bit of research in this meantime. I did discover what you just stated, DVD Player-Component, HD Cable Box-DVI. So i'll be going with that concept.
    Time Warner provided a basic Component Cable. I already own 2 Acoustic Research Component Cables. I'm using one to connect my DVD player to my HDTV.
    I did also find out that i need to get a DVI-D Cable. I've seen some options on the Internet, ramelectronics was actually one of them.
    Thanks again.
  4. I have been very impressed with the quality performance and value of cables from the following vendor:
    http://stores.ebay.com/Beyond-Comput...Q3amesstQQtZkm
  5. Originally Posted by Eyedoctor2
    Wow! They have definitely got awesome prices, and great stock! I'll certainly be purchasing my cable & adapters from them. Thanks, i appreciate this.
    Mickey
  1. Replies: 16
    Last Post: 25th Feb 2012, 16:20
  2. Plug DVI/HDMI adapter to DVI video card?
    By Stealth3si in forum Media Center PC / MediaCenters
    Last Post: 23rd Dec 2010, 19:32
  3. Connect VGA/DVI/HDMI source to Component HDTV
    By jstewar9 in forum Media Center PC / MediaCenters
    Last Post: 13th Jan 2010, 15:11
  4. DVI - HDMI - DVI problem
    By rbjt in forum Media Center PC / MediaCenters
    Last Post: 4th Aug 2009, 23:14
  5. Composite to HDMI/DVI/component Conversion
    By Gromit137 in forum DVB / HDTV
    Last Post: 30th Oct 2008, 11:10
