VideoHelp.com Forum
    I just bought a JVC Everio GZMG27 20GB HDD Digital Media Camcorder with 32x Optical Zoom [NTSC] and I would like to use it in a web conferencing context - namely have the camcorder act the same way a web conferencing camera would - where the picture generated by the camcorder shows up "live" in the web conferencing application (example: Yahoo Messenger or AOL instant messenger)
    Any help you can offer in this regard would be greatly appreciated!
    Thanks,
    Jay
  2. Member unclebud's Avatar
    Have you tried the firewire port and does Yahoo or AOL see it.
    Does it have a USB port, try that also. You should not need drivers for either connection on XP.
  3. Member edDV's Avatar
    JVC website doesn't mention USB streaming. Does the manual?
    The only software that will work with a USB2 device is packed with it (usually). Does the manal mention DV emulation?
    http://www.kiva.org/about
    The manual doesn't mention it nor does it work in a plug and play context when I use the USB firewire - I was thinking I would have to buy some kind of digital converter - one of those devices where I plug in the wire that I use to connect the camcorder to the TV and it converts it to a signal that works with the USB port...
    If anyone has any suggestions on doing this or any other way to do it would be greatly appreciated...
    Thanks,
    Jay
  5. Member edDV's Avatar
    I noticed in the introduction of Microsoft SP2 that there was a DirectShow provision for DV format emulation over USB2 using a WDM class driver.
    http://windowssdk.msdn.microsoft.com...deodevices.asp
    I haven't yet seen this included in a consumer video device. If they would do this, it might be possible to use DV format interfaces and tools with a USB camcorder or transcoder. That would require that the device manufacturer write the software since each of these devices use proprietary drivers.
  6. Member edDV's Avatar
    Yahoo Messenger webcam device requirements
    "Yahoo! Messenger webcams work with cameras that support ALL the following.
    1. VFW (Video For Windows) or Microsoft Direct Show.
    2. Both 160x120 and 320x240 image sizes.
    3. One of RGB, I420 or IYUV image formats. "
    http://help.yahoo.com/help/sg/mesg/w...ebcams-10.html
  1. JVC Everio GZ-MG465 Camcorder records for 2 seconds only
    By Garyl in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 20th Nov 2011, 01:12
  2. Utility for JVC Everio Camcorder
    By masfia in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 6th Sep 2010, 04:53
  3. Date/time stamp transfer on JVC Everio HD camcorder
    By lakin007 in forum Video Conversion
    Last Post: 11th Jul 2010, 17:37
  4. Date/time stamp transfer on a JVC Everio HD camcorder
    By lakin007 in forum Newbie / General discussions
    Last Post: 6th Jul 2009, 23:45
  5. Remote control JVC Everio GZ-HD10U camcorder.
    By 872156 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 10th Jun 2009, 16:51
