VideoHelp.com Forum
  1. I had thought I read somewhere there is a way to bypass admin rights on xp..is this possible?
  2. Member Faustus's Avatar
    Not REALLY. There is at least one program that can pick out the admin password on a system but you have to have admin access to use it. (doh!)
    There are also programs to RESET the admin password I think though.
  3. Member Treebeard's Avatar
    I use a program that can boot from floppy or cd and allows you to view or change the admin password, comes in handy if someone forgets it.
  4. Member Doramius's Avatar
    You can use the XP disk to remove the password, but it's not a short an easy process. No way to bypass though. If its an OEM PC then you MUST have the OEM XP disc. You could borrow someone esles Compaq XP disc if you have an OEM Compaq machine, but if they have a retail version, Dell, Gateway, or other OEM XP disc, you're probably screwed.
    There are other softwares out there, but again it's not easy. If you forgot your password and you are in an admin account, there is a software, like Faustus said, that you can use to see the password. But you have to be in an admin account, though it does not have to be the primary.
  5. VH Veteran jimmalenko's Avatar
    Yep, I think I found that same program via google and it got me out of a tight spot at work just the other week.
    If in doubt, Google it.
  6. Banned
    Did that once via XP boot, bit convoluted (not that much) but works. Disk Commander as far as I remember has the back door as well and of course the stuff mentioned above.
  7. VH Veteran jimmalenko's Avatar
    Originally Posted by ps2daddy
    Yep, that's exactly what I was talking about.
    I PM-ed those exact same links to scustalow about 4 hours ago
    Worked flawlessly on three seperate machines.
  1. VLC Media Player asking for Admin Rights !!!
    By gonwk in forum Newbie / General discussions
    Last Post: 10th Dec 2011, 23:37
  2. MPEG2 Rights
    By cyberboy in forum Authoring (DVD)
    Last Post: 8th May 2009, 00:00
  3. Need Admin Help!
    By Husk3r in forum Feedback
    Last Post: 17th Feb 2009, 15:59
  4. xp administrator rights?
    By edong in forum Computer
    Last Post: 9th Aug 2008, 16:25
  5. Music rights
    By kippard in forum Audio
    Last Post: 7th Mar 2008, 05:42
