Is there a way to double check the field order of a cap?
Didn't see a tool...
No problems...just want to see for myself.
Thx
Results 1 to 13 of 13
Thread: Field order
Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
There used to be a guide in the guides section here, but I cannot seem to locate it.
If in doubt, Google it.
99.9% of the time it depends on the capture source. DV devices are BFF, capture cards are TFF.
http://www.videohelp.com/forum/viewtopic.php?t=257631
Yes...I noticed that.
I guess it's included with most editors
People have the fields mixed up
Perhaps a tool to make this clear would helpAuthor, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Ya-ha .... found what I was looking for earlier.
http://forum.videohelp.com/viewtopic.php?t=194728If in doubt, Google it.
No offense, but I don't find that thread to which you linked helpful at all. Well, fmctm1sw had it right, but he was too terse, and was ignored anyway. If you have AviSynth installed, then, quoting from the DecombTutorial.html:
So, if it plays smoothly, your clip is TopFieldFirst (TFF), and if it jumps back and forth, it's BottomFieldFirst (BFF).To determine the field order, make an Avisynth script that serves the raw clip without any processing. If it were an AVI, then just AviSource() would be used. For our examples, we'll use AviSource(). Add a script line to separate the fields using top field first, as follows:
AviSource("C:\Path\To\Video.avi")
AssumeTFF().SeparateFields()
Now serve the script into VirtualDub and find an area with motion. Single step forward through the motion. Note whether the motion progresses always forward as it should, or whether it jumps back and forth as it proceeds. For example, if the field order is wrong, an object moving steadily from left to right would move right, then jump back left a little, then move right again, etc. If the field order is correct, it moves steadily to the right.
If it's a vob or mpg, then you use MPEG2Source after making a D2V project file using DGIndex:
MPEG2Source("C:\Path\To\Video.d2v")
Are you talking to me ?Originally Posted by manonoIf in doubt, Google it.
Yet ironically the method as described essentially is doing the same thing (removing one entire field) ?
I'm one of those that doesn't use TMPGEnc, but no, the AviSynth method isn't removing one of the fields. What it's doing is splitting the video into its component fields, and assigning one of them to play first (TFF, in the example). So, following that script, if the source was 720x480 and 29.97fps, the script will give you a video of 720x240 and 59.94fps. If you play it and it plays smoothly, it really is TFF. If you play it and it plays jerkily, it's really BFF. And if you then replace AssumeTFF() with AssumeBFF() and play it, it should play smoothly. It's foolproof and, based only on what I read in your link, and remembering back to my TMPGEnc days so many years ago when I needed it for IVTC, the AviSynth method for determining field order is also easier.
Oh, and I forgot to mention, if your source is a vob or mpg, you open it in DGIndex and run the Preview. The Information screen that opens up will immediately tell you the field order.
I see it in TMPGEnc now...the default wizard threw me off.
My neighbor got a high speed connection and a dvd burner. He doesn't do video but grabbed all these aps and handed them to me on 2 data discs. Old versions of Vegas, Pinnacle, TMPGEnc, Vdub, tons more. I'm only now going thru them because I haven't needed anything.Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Sorry, bad choice of words.Originally Posted by manono
Yeah, possibly. I am just the messenger though after all.Originally Posted by manono
Although learning to script isn't exactly the easiest for the type of people who don't know what their field order is. Personally it really doesn't bother me, as I know what I'm getting, every time
Put this AVISynth script in VirtualDubMod's Template folder as TestTFF.AVST:Originally Posted by jimmalenko
#ASYNTHER TestTFF
[DirectShowSource("%f")]
AssumeTFF()
BOB()
When you open a file with VirtualDubMod use the "Use AVISynth Template" pulldown at the bottom of the Open Video File dialog to select the TestTFF template. Now you don't have to write a script every time you want to test.
Field Order Question
By daz1976 in forum DVD RippingReplies: 2Last Post: 11th Feb 2010, 09:27 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
Determining field order
By dadrab in forum Video ConversionReplies: 2Last Post: 4th Oct 2007, 15:09 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 12th Sep 2007, 16:14 -
Need to change field order
By Loko in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 20:32
