VideoHelp.com Forum
Results 1 to 11 of 11
  1. Has anyone had ANY success with MSU's new logo removing filter? From the tests they show, it works great, but I have not had ANY success with it at all here.
    If anyone has been able to achieve success with this filter, please post your results here.
    The newest version of the filter can be downloaded here:
    http://www.compression.ru/video/logo.../index_en.html
  2. VH Veteran jimmalenko's Avatar
    I have not had ANY success with ANY logo removal wondertoys ...... EVER
    If in doubt, Google it.
  3. Originally Posted by jimmalenko
    I have had good success with Delogo on Alpha Blended logos, but not on the solid logos.
  4. No one else tried the MSU filter yet?
    I have found it better than the other delogo filters-once the area of the logo is marked as accurately as possible. I prefer putting a logo of my own if the original is too destracting
  6. How are you marking the area of the logo? When you say "marked", do you mean telling the filter where the logo is? If so, how are you figuring out where that area is?
    Thanks!
    I tried this filter a year or so ago, and I had to use trial and error to get the positioning right.
    Because the filtered area was a straight edged rectangular box, it was VERY intrusive on playback, worse than the logo itself. It was a bit like having a PIP within the movie.
  8. The newest version looks like it would do a good job, but has trouble making the mask if borders are black. No simple way to find the area where the logo is to tell the filter where to look.
    hit preview button
    adjust values of location as shown
    hit update preview button
    repeat till you've got it right
    uncheck the draw mask box and proceed
  10. Thanks. Sure takes a while to find the correct placement. I still can't say the filter works very well yet. Will try making a mask and see if that helps. MSU needs to make it so you can turn the filter on and off, for the caps that don't have a log all the way thru.
  11. Tried making a mask, and that seems to work better, but delogo still works far better.
  1. best practices when using MSU logo remover with virtual dub
    By snafubaby in forum Newbie / General discussions
    Last Post: 17th Jul 2011, 07:21
  2. Help needed with MSU Subtitle Remover in VDub
    By Lippy Lipstick in forum Subtitle
    Last Post: 5th Mar 2010, 08:03
  3. MSU subtitle remover, the great lie!
    By driva in forum Newbie / General discussions
    Last Post: 27th Dec 2008, 19:37
  4. frustrated with VDMOD and MSU sub remover
    By volam in forum Subtitle
    Last Post: 7th Feb 2008, 08:45
  5. VirtualDub MSU Subtitle Remover directions help
    By LangleyM in forum Subtitle
    Last Post: 6th Feb 2008, 07:56
