Results 1 to 17 of 17
    Is there software for upconverting SD video to HD 1080i?
    Googling did not yield any results but I have heard that there is software that can do this.
  2. Hi-
    AviSynth can do it for you, if I understand you correctly. It can resize it, telecine it, if necessary, even sharpen it up a bit. It can then frameserve to the encoder of your choice. The whole exercise sounds kind of pointless to me, though.
  3. Member Soopafresh's Avatar
    Yeah, you can do it, but it won't look very good at all.
    Originally Posted by manono
    Hi-
    What I am looking for is the 'encoder of your choice'? I am not aware of an mpeg encoder that will allow you to specify 1920x1080, do you know of one that will?
    BTW I whole heartedly agree that it would probably not look good but I am one of those people who has to see it for myself.
    Below is the thread where DrP claims this software exists and that the result looks pretty good!
    http://www.videoredo.net/msgBoard/showthread.php?p=17183#post17183
    Hi-
    I took a look at the URL and DrP seems pretty sure there is a fair amount of software that will do the SD to HD. However, I can not seem to find anything!
    I have Procoder, CCE and few other mpeg encoders and none of them let you output anything even close to 1920x1080. I will keep looking!!
    bits
    TMPGEnc Plus will let you encode at 1920x1080 if you pick one of the High profiles.
  7. Член BJ_M's Avatar
    many mpeg encoders will do hd ...
    main concept
    tmpgenc
    canopus
    pixel tools
    main concept
    tmpgenc
    canopus
    pixel tools
    Which Canopus product? I have Procoder Express and it does not allow it.
    I have just downloaded TMPGenc Plus Trial and I can not find a way to do it, although there may be restrictions on the trial.
    I will check out Pixel Tools. ---> At $4,000.00 this in not really an option!
  9. Член BJ_M's Avatar
    pixel tools is 4000$
    canopus procoder does HD
    tmpgenc does HD
    main Concept does HD
    use high level, main profile in all the cases above ...
  10. Член BJ_M's Avatar
    no one ever said hd is cheap ...
    and to get really really good upconversion quality takes a lot of skill and time (or a lot of money)
    TMPGEnc:
    Setting -> Video
    Unlock the "Profile & Level" field and set it to "High Profile and High Level (HP&HL)".
    Then set the frame size. And remember to use a much higher bitrate than normal.
  12. Yeah, DrP is talking about the same thing I had in mind. If you're handy with AviSynth, you can get some very surprising results. Here are a couple of threads that might help you:
    http://forum.doom9.org/showthread.php?t=70916
    Page 7 of that thread has some pics with before and after.
    LimitedSharpen is my favorite AviSynth sharpener:
    http://forum.doom9.org/showthread.php?s=&threadid=84196
    Here's an AviSynth page to get you started with LimitedSharpen. I use LimitedSharpenFaster.:
    http://www.avisynth.org/LimitedSharpen
    Some (most?) of those guys in those threads are doing this for AVI (XviD mostly). There's nothing that says it has to be for MPEG-2. Use a good high bitrate matrix and the results can be astounding.
    Originally Posted by jagabo
    TMPGEnc:
    Setting -> Video
    Thanks! I found it and it is working.
    Thanks also! I will look more at this tomorrow.
    Sounds interesting. If anyone actually tests these things then please report back with your results.
    TC
    My Dell PC system info.....3.0 Ghz Dual Core processor....... 8 gigs of ram DDR2...... Windows 7 professional 64 bit.......video card 1 GB memory DDR5 ram 800 mhz clock speed
  15. Member Noahtuck's Avatar
    You do realize this is a 4 year old dead thread.... right ?
    The OP has not even been on site for 3 years!!
    LOL!!
    Originally a member since 2001, LONG LIVE TARAN's!!!
    Power DVD 10 does a pretty good job, but it only works on files. You would have to rip the files on to your hard drive.
