Hi all... this is my first post after trying many time to encode a 640x272 divx to 720x576 dvd... i solved using mpeg2enc insted of ffmpeg... the problem is that when I try to encode the divx with flags -Z 720x306 -Y -135 with ffmpeg, dvdauthor say me that the final resolution is unknown... it's a strange thing... transcodee say that the final resolution is 720x576... no problem with mpeg2enc...
This is the transcode output with ffmpeg during conversion:
dvdauthor give me these messages : WARN: unknown mpeg2 aspect ratio 1Code:redirect@gentoomachine ~/Films $ transcode -i TUONO\ BLU\ \[DIVX\ ITA\]\ \[AZIONE\].avi -x mplayer -y ffmpeg -F mpeg2video -R 1 -w 10200 -D 0 --use_rgb --export_frc 3 -Z 720x306 -Y -135,0,-135,0 -E 48000 -b192 -N 0x2000 -o tuonoblu -m tuonoblu.ac3 transcode v0.6.14 (C) 2001-2003 Thomas Oestreich, 2003-2004 T. Bitterberg [transcode] (probe) suggested AV correction -D 0 (0 ms) | AV 0 ms | 0 ms [transcode] auto-probing source TUONO BLU [DIVX ITA] [AZIONE].avi (ok) [transcode] V: import format | DivX5 RIFF data, AVI (V=mplayer|A=ac3) [transcode] V: import frame | 640x272 2.35:1 [transcode] V: zoom | 720x306 2.35:1 (Lanczos3) [transcode] V: clip frame (->) | 720x576 [transcode] V: bits/pixel | 0.984 [transcode] V: decoding fps,frc | 25.000,3 [transcode] V: multi-pass | (mode=1) writing data (pass 1) to divx4.log [transcode] A: import format | 0x2000 AC3 [48000,16,2] 192 kbps [transcode] A: export format | 0x2000 AC3 [48000,16,2] 192 kbps [transcode] V: encoding fps,frc | 25.000,3 [transcode] A: bytes per frame | 7680 (7680.000000) [transcode] A: adjustment | 0@1000 tc_memcpy: using libc for memcpy [transcode] V: video buffer | 10 @ 720x576 [import_ac3.so] v0.3.2 (2002-02-15) (audio) AC3 [import_mplayer.so] v0.0.5 (2003-03-10) (video) rendered by mplayer | (audio) rendered by mplayer [export_ffmpeg.so] v0.3.13 (2004-08-03) (video) Lavc51.0.0 | (audio) MPEG/AC3/PCM [import_ac3.so] AC3->PCM [import_ac3.so] tcextract -a 0 -i "TUONO BLU [DIVX ITA] [AZIONE].avi" -x ac3 -d 0 | tcdecode -x ac3 -d 0 -s 1.000000,1.000000,1.000000 -A 0 [import_mplayer.so] mplayer -benchmark -noframedrop -nosound -vo yuv4mpeg "TUONO BLU [DIVX ITA] [AZIONE].avi" -osdlevel 0 > /dev/null 2>&1 [import_mplayer.so] tcextract -i ./stream.yuv -x yv12 -t yuv4mpeg | tcdecode -x yv12 -g 640x272 tc_memcpy: using libc for memcpy tc_memcpy: using libc for memcpy [export_ffmpeg.so] Using FFMPEG codec 'mpeg2video' (FourCC 'mpg2', MPEG2 compliant video). [export_ffmpeg.so]: WARNING: Interlacing parameters unknown, use --encode_fields [export_ffmpeg.so]: INFO: No profile selected [export_ffmpeg.so] Neither './ffmpeg.cfg' nor '~/.transcode/ffmpeg.cfg' [export_ffmpeg.so] found. Default settings will be used instead. [export_ffmpeg.so]: INFO: Starting 1 thread(s) [export_ffmpeg.so]: INFO: Set display aspect ratio to input [mpeg2video @ 0x2aaaaddf43d0]removing common factors from fram [encoding frames [000000-004396], 31.53 fps, EMT: 0:02:55, ( 7| 1| 0)
If i try to play the mplexed mpg (multiplexed with mplex) there are black bars also on left and rigth... not with mpeg2enc... where is my error.. thanks and sorry for my little english
I am not Linux user (maybe one day...), but mpeg2 for DVD should have 4:3 or 16:9 (also known as anamorphic) aspect ratio. If the aspect ratio is any other dvdauthor would throw such an error. I couldn't see such figure (4:3 or 16:9) in the output. But this line
give me a hint that ffmpeg sets the aspect ratio as the input. Your input is an divx avi and avi's in general have 1:1 aspect ratio. You need to find a way to force ffmpeg to write to output the correct aspect ratio (4:3 or 16:9).
ffmpeg can transcode both audios on "dual avi"?
By CactusMan in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2012, 07:25 -
Problems Encoding DVD with mpeg2enc
By justin35 in forum ffmpegX bugs and suggestionsReplies: 8Last Post: 11th Nov 2009, 14:07 -
VOB to .H264 FFmpeg Transcode Bitrate and Slow Seeking
By Gloriosis in forum Video ConversionReplies: 3Last Post: 9th Sep 2009, 14:34 -
Extensions (ffmpeg, mencoder, mpeg2enc) what do they mean
By loveformetal1 in forum ffmpegX general discussionReplies: 4Last Post: 18th Jun 2007, 01:30 -
Problems w/selectable subs avi-DVD w/mpeg2enc
By kenzo69 in forum ffmpegX general discussionReplies: 1Last Post: 20th May 2007, 05:53
Statistics
Newest guides
Latest tool updates
New media comments
