  1. I have downloaded big file end with .ts. How to open this file? It looks like an image of DVD because its size is 4.3GB.
    WU
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    More likely it is a digital tv broadcast.
    Try VLC.
    http://www.kiva.org/about
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    TS means Transport Stream.
    VLC will play it.
    Or MPC
    Or a mpeg2 codec and the hdtv pump filter and your favorite directshow video player.
  5. Thanks all. It can be opened by most of player. Now I am wonder how to burn it to DVD so that it can played by DVD player.
    Wu
  6. I'm a MEGA Super Moderator Baldrick's Avatar
  7. I cannot install this because it requires .Net 1.4. I have .net 2.0 installed. Need wait for new version
  8. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    you could try this one - HDTVtoMPEG2 - it will convert the ts stream to an mpg2 that you can re-encode to dvd specs if you want.
