Alright i dont know what its cause by but i use to love this software until i notice alot of problems it had with encoding. I mostly like it because of its functionality. being able to add mutlple videos with chapters and all that without the program trying to "fix" your video to be dvd compatible. Anyway my problem with the software is that after it changes the video to vobs and add chapters the video lose compatibillity with my dvd players. One of them wont even play the video and the others skip constantly at chapter intervals. Im wondering has anyone ever had these problems and fixed them. Also im wondering is there any other software out there that doesnt "fix"(by fix i mean trying to take 30 minute svcd video and turn it into a 1gb video file.)than tmpgenc dvd author.(this is the only program that i know that has alot oof features and works perfectly on my dvd players.)Dont recomend diko it sucks!bought it and it just doesnt load up any of my video.
Thread: SVCD2DVD problems with dvds
I just saw on the svcd website that some problems have been fix with skiping
When creating your DVDs, convert PAL to NTSC (no jerkiness or skipping).
is this the issue im talking about and is it solved
If you are starting with SVCD, not all DVd players are going to be compatible with the output. SVCD2DVD will not turn a true 30 minute svcd file into a 1GB file unless it combines assets under the same VTS, then yes you will get a larger VOB. As to your last question, how can we know if this is your issue? Provide a log file from a problem run.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
Well i found that the problems are non existant now thanks
this program is one of the best
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Problems using SVCD2DVD converted assets in DVDLab
By techboy_66 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Apr 2008, 16:28 -
SVCD2DVD Audio problems
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 6th Mar 2008, 10:53 -
SVCD2DVD Vista problems
By blondeguysteve in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Nov 2007, 09:35 -
SVCD2DVD 2.5 Problems
By mistalcote in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Aug 2007, 03:31
Statistics
Newest guides
Latest tool updates
New media comments
