Hello,
I am working on a project, but I have a small section in the video where the main audio track has a second commentary/narriation audio track on top of it. You can hear both tracks at the same time.
Is there a way to remove the second (commentary/narriation) track, so that the end result is just the one main audio track?
THANKS!!!!!!
Chris
is it just one audio track in the video file? or an avi,dvd, etc with several switchable audio tracks?
if just one audio track with mixed stereo channels it is very difficult to remove added narrations sounds.
It appears to be one audio track in the video file. The file is in .VOB format right now. I can demux it though, but I don't know if that will make a difference in terms of what format the file is in.
It there is only one audio track there is only one audio track. Some kind of fancy filtering may remove (most of) the voiceover, but it won't be an easy task.
/Mats
BATCH remove audio track from mkv
By MarquisdeOz in forum AudioReplies: 20Last Post: 2nd Aug 2011, 01:30 -
How to remove audio track?
By MAAG in forum AudioReplies: 12Last Post: 19th Jun 2011, 03:42 -
How do i remove an audio track from an AVI file?
By alih786 in forum AudioReplies: 22Last Post: 3rd May 2011, 03:26 -
how can i remove wind noise from a audio track
By suomiaussie in forum AudioReplies: 2Last Post: 23rd Mar 2008, 09:10 -
Adding an Audio/Music Clip into the main Audio Track?
By Moontrash in forum EditingReplies: 3Last Post: 20th Nov 2007, 17:45
