is there a Divx player that doesnt require you to install any files?
i.e. just an executable?
Results 1 to 9 of 9
Thread: Standalone DivX/XviD player
A VERY old noob
Nope. You must install proper codecs in order to display video files.
does the codec require to be registered in the registry?
A VERY old noob
Yes. I also do not know of a single player that will run without installation files. why do you need it?
Try VLC Media Player. It has it's own codecs. You're probably looking for a player that can be included on a disc to play the Divx/Xvid automatically without installing. I don't believe VLC will do that, but it does have versions for most OS platforms.
You don't have to install VLC?
thanks baldrick, so I do not need to install the codecs in order to play Divx with mplayer?
A VERY old noob
mplayer requires no install and has built in decoders/splitters for most stuff and can load external dll's/ax's. Doesn't support DivX menu's, chapters, etc. though. Default options can be set in the config file like fullscreen, number of audio channels to output, etc. When compiled with cpu runtime detection it will run on any CPU to.
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 08:32 -
Standalone Divx/Xvid player with remote & usb
By bxr510 in forum Media Center PC / MediaCentersReplies: 5Last Post: 19th Aug 2008, 06:19 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24 -
Standalone Divx/Xvid player Q
By g0dm0de in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2007, 23:14
