Hi, I've been trying to mux 1 audio-less .avi file and 1 video-less .aac file. I've also tried it after converting the .aac file to .mp3. However, the progress bar simply does that moving grey thing that means that nothing's actually happening. I've left it on for some 6 hours before, and nothing gets done.
Can someone help me out here? Is there something I'm missing? I'd really appreciate it, thanks.
I just went through the gauntlet trying to mux AC3 6 channel into an avi, so I'm speaking from recent experience. First, you can't put an AAC into an AVI, doesn't work. A better choice is AC3 or MP3. Constant Bitrate MP3 that is, please don't put a Variable Bitrate MP3 in a movie...
And, the version of ffmpeg that's in ffmpegX generally doesn't like AACs. You would be better off using something else to convert an AAC to whatever. Once you have a 'good' stereo AC3 or MP3, ffmpegX should mux it without a problem. I've also had good luck using D-Vision 3 to mux stereo AC3 and MP3 audio.
My recent bout ended in VPC and XP to use Virtual dub to mux a Compressor generated AC3 5.1 audio file with a ffmpegX created Xvid video that would work correctly in QT. The AVI muxed by ffmpegX always ended with an audio file seen as way too short in QT. And apparently, D-Vision doesn't do 5.1 audio. Had to use a PC just to mux a 5.1 audio file...pathetic....
Hi
there's another option for muxing your files. if you don't care that the container isn't an .avi, then you could use the .mkv (matroska) format...
this container supports about every audio/video-format. I myself mux Xvid- or h.264-Video and variable Bitrate AAC-audio without any problems. multi-channel AC3 wouldn't be a problem either...
one negative point is that it's command line, but if you're just a bit familiar with the terminal it works great...
the tools are called mkvtoolnix
http://www.versiontracker.com/dyn/moreinfo/macosx/23606
BTW: .mkv supports additional subs and chapters etc. it's really cool
hope it helps
Audio in my video doesn't work on all computers
By MattMedia in forum AudioReplies: 4Last Post: 26th Jan 2011, 10:40 -
Mpga Audio in Vegas 9.0 doesn't work
By NarutoS212 in forum EditingReplies: 3Last Post: 24th Dec 2009, 19:47 -
Audio doesn't work on HDMI. Something wrong with the TV?
By Xavier in forum Software PlayingReplies: 1Last Post: 14th Oct 2009, 00:07 -
[AVI] Muxing aditional audio
By Wacken88 in forum LinuxReplies: 0Last Post: 25th Jun 2009, 09:56 -
convert avi to dvd with ffmpeg doesn't work-why?
By lilly333 in forum ffmpegX general discussionReplies: 21Last Post: 18th Mar 2009, 16:00
Statistics
Newest guides
Latest tool updates
New media comments
