VideoHelp.com Forum
Results 1 to 24 of 24
  1. Member SingSing's Avatar
    http://www.buy.com/retail/product.as...70&dcaid=17070
    This is the first $200 19" LCD monitor that has more than the usual 1280x768 resolution. You get 1440 x 900 out of this one.
  2. Member FulciLives's Avatar
    Sounds interesting but is it a 16x9 monitor? It says widescreen but the image of the product doesn't look like it is 16x9 or anything other than your standard 4:3 ratio?
    Also what is going on with the new "Vista" version of Windows? I've heard that to be able to play back HDTV video that you will need a new type of monitor that supports DRM and to the best of my knowledge such monitors do not yet exist.
    I guess I am implying that now seems to be a "bad" time to buy a monitor if things will be changing in the near future.
    Best not to buy one if the current monitor is A-OK.
    - John "FulciLives" Coleman
  3. Banned
    No where near is this the first widescreen 19" LCD. Acer has the best one in the AL1916W model. Other notables are Dell, Samsung, Hitachi, Viewsonic, etc.
  4. Member SingSing's Avatar
    But none of those LCD are at $200+.
  5. Член BJ_M's Avatar
    sgi had a widescreen "SGI 1600sw" that still blows a lot of newer lcd out of the water - and that model is over 6 years old ...
  6. Член BJ_M's Avatar
    btw -- you want to see some nice monitors and equipment ..
    http://www.videomonitor.co.kr/PD_02e.htm
  7. Member SingSing's Avatar
    I was hoping this tread is about low cost, high res LCD monitor.
    We kind of know most LCD came from Korea and China. The branded and the less known LCD monitor can be the same panel under them.
    But LCD is tought to buy online. 1. We don't known what it LOOK like. 2. Are these rejects with a few dead pixels to start with ?
  8. Banned
    All of them excluding the Dell is cheaper than the one you listed. I've bought 2 Acer AL1916W @ $238. http://www.mwave.com/mwave/viewspec....iteria=3926616
    It's not tough to buy online. You just need to buy from a reputable source with a good RMA policy. If you buy your panels off Ebay, you get what you pay for.
  9. Член BJ_M's Avatar
    it doesnt have DVI input which kind of s*x .... though at that price , i guess you should not be fussy ...
  10. Member SingSing's Avatar
    Thank you. This is what I was looking for.
  11. Originally Posted by ROF
    some companies that sell stuff on ebay have decent return policies, you just gotta be careful and be sure to buy from someone with a ton of feedback (i generally look for 20,000+ feedback when buying something from ebay, it's generally a lot safer than buying from individual sellers....)
    It has kind of a funky screen size/resolution, 16x10.
  13. Member SingSing's Avatar
    I think it is same as one of the laptop display resolution ( I think it's Dell ).
  14. Banned
    It's the same for most wide screen computer LCDs.
  15. Member SingSing's Avatar
    Found this at compusa ( local to me )
    http://www.compusa.com/products/prod...pe=ts#moreinfo
    Does Envision honour and process their rebate promptly ?
  16. Banned
    I tend to do nearly the exact opposite. Of course, I'd never buy my computer parts off Ebay but people with 20,000+ feedback usually do not have the niche items which makes Ebay so attractive to most buyers.
    hmmm, never noticed that before but then i never shopped for a widescreen computer monitor. why are the LCD monitors 16x10 but the LCD TVs are 16x9?
  18. Member edDV's Avatar
    "Contrast Ratio: 500:1" -- a computer panel
    "Signal Input: D-Sub, Analog" -- That would be VGA no? Or what?
    Just another cheap computer monitor. No TV here.
    http://www.kiva.org/about
  19. Banned
    That would definitely be VGA. Why anyone would buy an analog panel is beyond me. I won't sell'em that's for sure.
  20. Member shoozleboy's Avatar
    V7 Monitors is the name used by Ingram Micro (large technology distributor) on monitors they have manufactured for cheap sale by Ingram. They wanted to get in on the parts market more and this was their start.
    They are decent for what they are. No digitial input though, only analog VGA.
  21. Member FulciLives's Avatar
    I guess I am behind the times but I've only ever had a CRT monitor.
    So ummm since when is a VGA output on a video card "bad".
    What is better?
  22. Member Conquest10's Avatar
    I know, right? Apparently DVI is the only acceptable connection these days.
    His name was MackemX
  23. Member
    I'm kind of missing the idea, I guess. I'm perfectly fine with my standard VGA output into my analog flat panel. Looks like video to me.
  24. Member edDV's Avatar
    Nothing wrong with VGA for general computer work. But 1440x900 is a non-standard size. Nearest are
    WXGA 1366x768
    SXGA 1280x1024
    UXGA 1600x1200
    The display card would need to support 1440x900. Or WXGA would need to be interpolated. Plus you may find it difficult to find games that support custom resolutions.
    http://grafi.ii.pw.edu.pl/gbm/matrox/ramdac.html
    http://www.gen-x-pc.com/lcd3.htm
    There will come a time when display cards loose the RAMDAC analog circuitry and use only DVI-D or HDMI.
  1. Replies: 1
    Last Post: 26th Apr 2010, 15:15
  2. HVX 200 P2 - Time Lapse "Recording Error" now file wont play or import!
    By trevmarps in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 25th Apr 2010, 16:08
  3. Replies: 4
    Last Post: 18th Apr 2009, 07:41
  4. "Watch This Video In Higher Quality" Link On YouTube
    By Leonardo in forum Video Streaming
    Last Post: 10th Apr 2008, 15:03
  5. Epson R-200 "Parts Nearing End Of Service Life..."
    By moviebuff2 in forum Computer
    Last Post: 25th Oct 2007, 07:27
