VideoHelp.com Forum
  1. Which one would you guys buy?
    I would get the HDR-HC1 it was awarded the best pick for under $2000 in 2005 and has been given great reviews check camcorderinfo.com for the full review. This site is one of the best when it comes to camcorders they perform some of the best tests out there and give scores to every feature. there rating system is #1
    This award was perhaps the easiest to give out. If you read our review of the HDR-HC1 you’ll immediately know how floored we were by this model. The gorgeous, sharp video, with its vivid colors, knocked our socks off. Better still, the inclusion of manual controls made us feel comfortable shooting with a Sony once again. No camcorders in the $1,250 - $2,000 range even come close to the HDR-HC1 in quality or anything else.
    gateway Gt5028
    athlon 64X2 dual core 3800+
    250 gb Hd
    1 gb ddr2 pc3200
    dual layer dvd+/-rw
    dvd rom
    video card PNY 6600 pro PCIe 256mb
    sound card sound blaster live
    Studio 9
    Boston acustic digital speakers w/ subwoffer
    17" LCD
  3. Member slacker's Avatar
    I would get the hc-3. It is gorgeous, and the retail price just dropped to $1500. Uses the same CMOS chip as the hc1 so why pay more.
    This has been talked about on other forums on the net.
    The new HC3 doesn't have a external mic input, no manual focus ring, however, has a tape top loading mechanism, and supposedly slightly better low light performance (according to the manuals floating around on the internet). People seem to be asserting that this model is slightly more 'consumerish' with the retraction of the headphone/mic options.
  5. Member slacker's Avatar
    I need to edit my post.
    The hc3 does allow for Sony's proprietary stereo or gunzoom external microphones.
  6. Member edDV's Avatar
    I'd go with the HC-1. The extra features are worth it to me.
    That was Sony's strategy. They took away some key features for the Prosumer and raised the price of the HC-1. Panasonic did some similar tradeoffs with the GS-500.
  7. Member slacker's Avatar
    Yes, but in the hc3 we see Sony finally committing to an overall design. The hc1 never did look "right", the designer was OTL. And it has some material issues as well if you scan the forums.
    I'll bet dollars to donuts the upcoming replacement to the hc1 and a1u looks EXACTLY like the hc3. The hc1 is already an over the hill design.
    Mark
  1. Sony HDR-HC3 - HDVSplit or winDv?
    By jefftaz in forum Newbie / General discussions
    Last Post: 20th Jan 2011, 14:10
  2. Sony HDR-HC3 HDV Capture
    By plugh in forum Capturing
    Last Post: 9th Aug 2009, 23:15
  3. Replies: 9
    Last Post: 4th Mar 2009, 12:57
  4. Best util to capture HDVIi from Sony HDR-HC1?
    By Raycaster in forum DVB / HDTV
    Last Post: 11th Feb 2008, 14:33
  5. Sony HDR-HC3/damaged Firewire port
    By alegator in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 19th Jan 2008, 22:08
