VideoHelp.com Forum
    Own a Sony DCR-HC21 Mini-Dv recorder.
    I took some footage of my band.
    I have 2 capture programs installed:
    a) Camera came with software called "Sony Picture Package".
    This capture program saves the video as a MASSIVE uncompressed AVI.
    b) MS-Movie Maker.
    This writes the video as a WMV file.
    I will use MovieMaker, b/c my goal is to share COMPRESSED clips on the web.
    The WMV is about 4MB/minute.
    QUESTION: What program can I use to EDIT the WMV and make it BRIGHTER?
    MovieMaker des not have this
    (Free preferred, but I am willing to buy a decent, easy to use app.)
    QUESTION: What software can I use to rip the WMV audio into MP3?
    QUESTION: If I want to make a TV ready DVD, I should capture as HUGE AVI, and then convert to MPG, right?
    Also, what formats can play DIVX?
    Shoud I be using this instead of plain WMV?
  3. Member MOVIEGEEK's Avatar
    I recommend Ulead VideoStudio for transfering DV,editing,exporting to WMV,extracting MP3 and authoring a DVD.Another free app for WMV is WME.
    There are many freeware tools to do each request but Ulead VS does them all.
    BTW...if you are going to stream video I recommend WMV because 90% PC's support it without additional codecs.Divx is good but a user must have the codec installed to watch.
    Can I adjust brightness easily?
  5. Member MOVIEGEEK's Avatar
    In Ulead VS yes,in WME I don't know.
  1. vsfilter making video output much brighter on mkv files
    By shmizan in forum Software Playing
    Last Post: 4th Apr 2010, 04:15
  2. combining WMV movie clips into one WMV clip
    By blkwht240 in forum Editing
    Last Post: 5th Feb 2010, 00:41
  3. what video software is best for making WMV or online videos?
    By kittykat3 in forum Newbie / General discussions
    Last Post: 20th Mar 2008, 17:46
  4. Replies: 5
    Last Post: 7th Feb 2008, 23:15
  5. How to convert wmv clip so its properties match other wmv clips
    By sohaibrazzaq in forum Video Conversion
    Last Post: 4th Aug 2007, 09:16
