How do u transfer DVD to computer at full screen to edit then burn back to dvd??
Every program ive tried only lets u convert to computer at like 720x 480 max screen size.
After you edit and burn it back to dvd the quality is gone because it now has to blow up the 720x480 video to full size and becomes choppy or blocky.
I dont know why this is a big deal or problem.
Anyone have the know how???
720 x 480 is full DVD resolution. That is as big as DVD gets. Your playback software may be able to play it back full screen, however it does this via tricks and filters. See What is DVD in the top left corner for details.
i dont get how i lost the quality then.
dv to dvd no problem
dvd to computer at highest quality and 720x480 at 30fps to avi file
Used Powerdirector to edited it ect..
burn back to dvd at highest quality
now its blocky
any one know what happened?
when you edit, your software most likely re-encodes the file and depending on which encoder you use and what setting you have the quality differs. give detailed information on what you use, which program etc
your taking an mpeg2, converting it to something, then re-encoding to an mpeg2 again. Your going to lose quality no matter what you do. How much quality you will lose is up to software/method. Like Infratom said: Give detailed informaton on what you use.
If you're capturing off DVD via analog then you're going to lose some quality. You may want to try ripping the DVD to your harddrive and then using a transcoder like Procoder to convert the DVD files, which are in mpeg2, to DV-format .AVI files which can be edited.
W
Tools like TMPGEnc MPEG Editor
http://www.videohelp.com/tools?tool=TMPGEnc_MPEG_Editor
allow you to cut DVD files without re-encoding.
If your looking at changing the content with titles and transistions you will have to re-render those parts of the video.
When you convert to AVI, what codec or type of avi do you create ? As pointed out, this is likely where you lose a lot of quality in the first place. Unless you use lossless or uncompressed, you will throw away information that you cannot get back.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 17:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
Webcammax makes the computer crash when recording full screen
By Nintendo Fan in forum Video StreamingReplies: 0Last Post: 1st Jan 2010, 17:08 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23 -
how do i transfer mini dvd to computer
By allaag in forum Video ConversionReplies: 1Last Post: 18th Jun 2007, 04:49
