VideoHelp.com Forum
    hi, i used to use im jet but then theyu closed down, the cartridges were dirt cheap and i could tell no difference from the originals, so what brands of ink do u guys in the uk use, p.s no continuous ink systems cos it always takes over threads
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Tried a all forum search for 'ink for R300' ?
    yep, nothing really relevant for people in the u.k, u'd think this would be a huge subject
    Tried a period or capitalization much?
    On topic: You could try www.megatoners.com. I've used them. You need to be very dilligent in making sure you print at least every two days or the cartridges clog. I believe there are some other sources that may be better. Try www.newegg.com also.
  5. Member e404pnf's Avatar
    Can't vouch for their use in an Epson printer but I use either inkrite (from ebuyer) or Jet Tec (from SVP) in my Canon i865.
    I know that doesn't really answer your R300 question but wanted to give you UK options. I've found these to be comparable to Canon originals and have no reason to think the Epson's would be any different.
    Hi, I use SVP for my supplies and have used Jettec regular and so far so good, even after several days without use never had a clogged problem yet (touch wood)
    Anyone tried getting their originals refilled at Cartridge world. They claim to use the same quality inks... I'm currently saving my old cartridges, and I was going to give them a try once I get a complete set together...
    Rob
  1. Replies: 12
    Last Post: 29th Apr 2011, 15:28
  2. Epson R260 Generic ink?
    By jayndenver73 in forum Media
    Last Post: 15th May 2010, 12:42
  3. Epson R320 ink cartridge ordeal....
    By rubberman in forum Computer
    Last Post: 25th Aug 2009, 14:47
  4. Looking for a CIS(Continuous Ink System)for an Epson RX580
    By Jake802 in forum Newbie / General discussions
    Last Post: 19th Jan 2009, 01:02
  5. Replies: 4
    Last Post: 13th Sep 2008, 08:19
