I have a quicksilver g4 800 with a cdrom/burner and a zip drive, can anyone help with information i have tried a search on xlr8 with no luck, on putting a pioneer 110d in place of the cdrom/burner and replacing the zip drive for a cd/burner/dvd/rom?
Iwould like to use this mac for all my backing up.
thanks
Results 1 to 9 of 9
Thread: zip drive
OWC (macsales.com) has a Quicksilver installation video
in its "support" section. It is quite informative. Plus they'll
sell you a 110 for $53.
Do you mean physically installing the drive or getting OS X to detect it?
"First god damn week of winter." --R.J. MacReady
Is actually looking at the OWC web site considered cheating?
Yes, it is.
The zip bay is smaller than a regular CD/DVD drive, so a replacement drive won't fit there without bending and/or removing other metal parts.Originally Posted by turdburglar
Thanks for your help, I swapped the cd burner with the pioneer 110D and everything works fine all the i apps recognise the drive but the region code only lets me change regions four more times, which is a bummer as I have DVDs from all different regions, as for the zip drive I dont mind modifying the case bur what about the cables/connections????
I thought you can rip discs with MactheRipper without having to change the region on your optical drive.
There is region free [RPC1] firmware (and also a means to turn on the Ram-writing capabilities of the 110D (turning into a region free 110). Check here:
http://tdb.rpc1.org/#DVR110D
You will want the 1.39 version
Use DVRFlash to install firmware.
Windows 7 does not see my Zip Drive
By kimco52 in forum ComputerReplies: 16Last Post: 22nd May 2010, 20:16 -
.Exe vs .Zip Programs
By gonwk in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2009, 03:30 -
What is your most used zip compression utility?
By yoda313 in forum PollsReplies: 39Last Post: 30th Jun 2009, 16:00 -
AviDemux .Zip vs .Exe
By gonwk in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 18:53 -
Can't unzip ffmpegXbinaries20060307.zip
By cerebusthe2nd in forum ffmpegX general discussionReplies: 4Last Post: 9th Dec 2007, 08:39
