Hi all,
I have family photos taken on my digi camera. I use Photoshop cs2 and premiere pro 1.5. When i get the images in photoshop I choose to alter the aspect ratio to pal 1.06, (not to sure of the exact number 1.06 or 1.066) Then I save the image as JPEG. I then burn the dvd using CBR 1 PASS 7 MEG.
The problem is when i play the dvd the images seem to shake slightly. It is like some pixels are moving in parts of the image. What have i done wrong?
Cheers Josel
Thread: Aspect ratio / Resolution
Nothing. I suspect what you are seeing is caused by interlacing on playback. Your TV shows each image i two passes - odd lines, then even lines (or vice versa - doesn't matter which), and it does this 25 times per second. Fine horizontal lines or very small points may appear to shimmer because they fall onto only one scanline.
To avoid this, apply a very small directional blur (either up or down) in photoshop. Usually something as small as 0.4 or less can fix the problem without causing noticable change to the image.
Resizing: Resolution and Aspect Ratio
By roflwaffle in forum Video ConversionReplies: 7Last Post: 9th Apr 2011, 08:25 -
Resolution and Aspect ratio
By Mrsash in forum Video ConversionReplies: 4Last Post: 19th Nov 2009, 16:37 -
Resolution vs Aspect Ratio
By triptych in forum Newbie / General discussionsReplies: 17Last Post: 7th Aug 2009, 07:23 -
Aspect Ratio/Resolution Question
By kidcash in forum Newbie / General discussionsReplies: 3Last Post: 4th Nov 2007, 03:43 -
Please explain Aspect Ratio and Resolution
By slmnow in forum Newbie / General discussionsReplies: 8Last Post: 21st Aug 2007, 19:14
Statistics
Newest guides
Latest tool updates
New media comments
