VideoHelp.com Forum
Results 1 to 16 of 16
    I need a stream information tool like g spot for SuSE 10.
    Does anyone know of any?
    Also what is the best avi-2-DVD converter for Linux. I am currently trying out avidemux.Do I need a seperate dvd author?
  2. I've moved this thread to the Linux Forum - hopefully it will get a reply more quickly here.
    (I'm afraid that I don't know Linux very well so I don't have anything to offer you)
  3. Member tekkieman's Avatar
    For avi to dvd, try tovid
    For avi info, try idvid. You will get it with tovid. There is also a manual for it on the tovid site. There is a large dependancy list for tovid, but I use debian, and apt-get handled it with no problem. One of the dependancies is dvdauthor, and that will handle the authoring (tovid provides an xml structure for dvdauthor)
  4. Member oldcpu's Avatar
    I also recommend tovid. It works fine on SuSE-9.3 and SuSE-10.0.
    One can download precompiled rpms (for SuSE) of tovid from here:
    SuSE-9.3:
    http://ftp.gwdg.de/pub/linux/suse/ap....suser-oc2pus/
    SuSE-10.0:
    I run tovid-0.23 on my SuSE-9.3, and tovid-0.25 on my SuSE-10.0. (I couldn't get tovid-0.25 to run on my SuSE-9.3, although clearly "suser-oc2pus" did succeed. tovid requires a newer version of python-wxGTK than comes with the baseline SuSE, and I didn't want to upgrade my python-wxGTK as it would have broken some other dependencies. But tovid-0.23 works fine for me).
    how do you get the gui to appear?
    It says its installed and when i type tovidgui in terminal the program runs but there is no gui?
  6. Member oldcpu's Avatar
    The list of tovid dependencies are here:
    http://tovid.berlios.de/en/dependencies.html
    To get tovid gui to run, you need wxPython 2.6 or newer.
    In my case, I run the tovid gui with: /usr/local/bin/tovidgui.py
    There is a tovid forum, where you can get good support to resolve difficulties:
    http://www.createphpbb.com/phpbb/index.php?mforum=tovid
    There is really but one alternative under Linux: Mplayer/Mencoder
    Read the docs on the website plus the man pages
    I have personaly tried all the gui's out there and the only thing for me that works good, is mencoder
    I have mplayer already installed how do i access the mencoder gui?
    command line gives error: file.avi not found recompile with -disablecpudetect
  9. Member oldcpu's Avatar
    Doesn't tovid call mencoder by default?
    Mencoder by itself does not have a gui. When I first came over from windows a few months ago I tried all the gui's out there, but I found the best solution was to use mencoder at the terminal. I read the guides over and over till I learned. learn the command line and you won't be sorry. The real power of linux is in the command line, using konsole, copying and pasteing from scripts makes life a lot easier
    as for a g-spot alternative try this: mplayer -vo dummy -identify inputfile.avi
    this is what it might retun::
    AVI file format detected.
    ID_VIDEO_ID=0
    ID_AUDIO_ID=1
    VIDEO: [XVID] 528x384 12bpp 29.970 fps 1306.5 kbps (159.5 kbyte/s)
    Clip info:
    Software: Nandub v1.0rc2
    Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
    AUDIO: 48000 Hz, 2 ch, s16le, 128.0 kbit/8.33% (ratio: 16000->192000)
    Selected audio codec: [mp3] afm:mp3lib (mp3lib MPEG layer-2, layer-3)
    ID_FILENAME=xdmnx-pph11.avi
    ID_VIDEO_FORMAT=XVID
    ID_VIDEO_BITRATE=1306480
    ID_VIDEO_WIDTH=528
    ID_VIDEO_HEIGHT=384
    ID_VIDEO_FPS=29.970
    ID_VIDEO_ASPECT=0.0000
    ID_AUDIO_CODEC=mp3
    ID_AUDIO_FORMAT=85
    ID_AUDIO_BITRATE=128000
    ID_AUDIO_RATE=48000
    ID_AUDIO_NCH=2
    ID_LENGTH=4143
    Good-luck
    http://www.mplayerhq.hu/DOCS/HTML/en/mencoder.html
  11. tcprobe from Transcode is good too.
    Good old 'file' command doesnt go astray when you only need simple info about the file.
    AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
    Jabber: DaveQB@jabber.org.au
    2.6.29.3-desktop-1mnb
    tovid is the best(well easiest converter for nix) check the developers out on irc.freenode.net #tovid
    whats that your reading hope its work (s**t caught again)
  13. is anyone aware of any tools, preferably command line, that will show if a file has been encoded using qpel and/or gmc ? i don't believe that either idvid or tcprobe will show this. thanks.
  14. to answer my own question and maybe help others. this tool shows qpel and gmc info :
    http://forum.doom9.org/showthread.php?t=87516
    Nope - ffmpeg
    ffmpeg -i filename
  1. G-Spot says its 4:3, but its really 16:9
    By Toastie in forum Video Conversion
    Last Post: 22nd Nov 2011, 07:54
  2. A linux alternative of DVDFab
    By andreltr in forum Linux
    Last Post: 11th Jun 2009, 09:21
  3. Replies: 5
    Last Post: 26th Nov 2008, 20:27
  4. G-Spot Help
    By serf423 in forum Newbie / General discussions
    Last Post: 31st Mar 2008, 09:07
  5. Replies: 0
    Last Post: 28th May 2007, 10:23
