Chrissyboy,
First of all thank you for creating vob2mpg!
I just have a small problem. It is working, but it is taking a long time to convert. I have a file which is about 2,5 gb and the computer has done about half now in 24 hours. If this is normal forget my question, but i read in other threads that somebody got in done in a few minutes.
I think i got the program to work the first time in installed it, but i couldn't believe that it was done so quickly (every thing else has taken hours) so i uninstalled it and a day later re-installed it. (don't know if this might be the problem)
So my question is, what am doing wrong.
Just a little information of what i have done. DVD ripping in DVD Decrypter IFO. In the VIDEO_TS folder i did find anoter folder named: agk_tmp. (autogk isn't working properly on my computer) I took this out and selected the rest of the folder in vob2mpg.
Since you have asked for the log on other threads, i figured i'd post it here so you might know what is going on.
Thanks for any information you migth give me.
Jules
************************ SYSTEM INFORMATION ************************
***************************** VOB2MPG *****************************
Title:
Version: 2.2.0.0
Executable: C:\Program Files\BadgerIT\VOB2MPG\VOB2MPG.exe
Executable size: 636 kB
Executable size in bytes: 651264
Executable CreationTime: 20-2-2006 9:56:28
Executable LastWriteTime: 20-2-2006 9:56:28
Executable LastAccessTime: 16-3-2006 13:24:13
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 451 MB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 2,01 GB
DeviceID: F:
FileSystem: FAT32
FreeSpace: 31,5 GB
********************* END OF SYSTEM INFORMATION ********************
********************** Input Folder *******************
14:24:38: De volumenaam van station F is TREKSTOR
14:24:38: Het volumenummer is 00AC-6BD4
14:24:38: Map van F:\BadGirls123\VIDEO_TS
14:24:38: 14-03-2006 15:51 <DIR> .
14:24:38: 14-03-2006 15:51 <DIR> ..
14:24:38: 15-03-2006 22:52 578.267.136 VTS_01_3.VOB
14:24:38: 15-03-2006 22:42 1.073.299.456 VTS_01_2.VOB
14:24:38: 15-03-2006 22:24 1.073.555.456 VTS_01_1.VOB
14:24:38: 3 bestand(en) 2.725.122.048 bytes
14:24:38: 2 map(pen) 33.882.144.768 bytes beschikbaar
14:24:38: F:\BadGirls123\VIDEO_TS>
14:25:42: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
14:25:42: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
14:25:42: libavutil version: 49.0.0
14:25:42: libavcodec version: 51.4.0
14:25:42: libavformat version: 50.2.1
14:25:42: built on Feb 15 2006 22:10:31, gcc: 3.4.4 (mingw special)
14:25:42: Input #0, mpeg, from 'multi:F:\BadGirls123\VIDEO_TS\VTS_01_3.VOB*F:\Bad Girls123\VIDEO_TS\VTS_01_2.VOB*F:\BadGirls123\VIDE O_TS\VTS_01_1.VOB*':
14:25:42: Duration: N/A, start: 2350.501344, bitrate: N/A
14:25:42: Stream #0.0[0x1e0], 25.00 fps(r): Video: mpeg2video, yuv420p, 720x576, 9000 kb/s
14:25:42: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
14:25:42: Assuming PAL for target.
14:25:42: Output #0, dvd, to 'F:\BadGirls123\video\VTS_01.mpg':
14:25:42: Stream #0.0, 25.00 fps(c): Video: mpeg2video, yuv420p, 720x576, q=2-31, 9000 kb/s
14:25:42: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 192 kb/s
14:25:42: Stream mapping:
14:25:42: Stream #0.0 -> #0.0
14:25:42: Stream #0.1 -> #0.1
Results 1 to 9 of 9
Thread: vob2mpg problem
Do you see the VTS_01.mpg file increasing in size? Is it an internal HD? Why is it FAT32?
Yes, it does increase in size.
I have laptop. My internal HD is 10 GB. So using a USB portal i have a second HD which is 40 Gb. On this disc i have the VOB files and that is also the place where the MPEG file is going.
Does that make any sense?
Yes it does. I suspect that that is a I/O bottleneck for the USB... is it USB 1.1 or USB 2.0?
I am sorry. I don't know what I/O bottleneck means.
It is USB 1.0, i think.
Ahh so if this is the problem. I guess it would be better to have small files on my D drive and convert there and then transfer it to the other HD when it is all done. Would that work?
File i/o: Basically the speed of the USB 1 interface is not up to the job here. You are copying 2.5GB to and from the External HD. And the transfer rate of the USB is too slow for this. Internally this would indeed take minutes rather than hours.
So do as much as you can internally (but i note you don't have much space)
If your input folder was on one drive and the output was another (and one of those happened to be the external drive) you would also see a hugh speed inprovement.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thank you so much!
I have emptied out most of the stuff i had on the internal HD, so i should be okay, as long as the files don't get bigger than this.
It will take a few more hours to have the present converting job done. Then i'll give it a go.
I'll let you know if it works!
ok.
(Also remember that your external drive is FAT32 and so has a single file limit of 4GB. So if you have a vobset which is over 4GB in total you would have another issue...)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Chrissieboy,
It works! I tried it on Saturday and it only took me 20 min! First i had a problem with the audio (there was none) but thanks to the AC3 filter, i now have audio too!
vob2mpg first run problem
By klex in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Apr 2012, 22:58 -
problem with VOB2MPG
By Onceler2 in forum Video ConversionReplies: 3Last Post: 16th Sep 2011, 13:12 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
vob2mpg problem
By branjk in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Oct 2009, 02:14 -
VOB2MPG v2.5 language problem
By akqz in forum DVD RippingReplies: 1Last Post: 8th Aug 2007, 11:27
