Howdi,
I have just installed Dragon Burn version 4.1.2 to be able to burn DL DVD to my NEC 3520 DL burner.
After adding the content of the video_ts files to the files list to burn I tried to burn it but after a few seconds the app tells me burn was successful. It states it took 0:42 althoiugh it took less time and nothing is written to the disc. I use Verbatim DL DVD+r discs. Dragon burn recognizes the burner and the Log file doesn't state any errors.
I burned a single layer DVD without problems using Dragon Burn.
I thought of updating firmware for the drive, but can't find any Mac versions.
Please help.
Are you certain that version of the software supports DL burns?
Check the small things before jumping into a firmware update - usually the simplest things are the ones that cause these issues.
Good Luck!
TTWC"I've got a present for ya!" - TTWC
Can't burn DVD using TDK burner
By tee jay in forum MacReplies: 7Last Post: 16th Sep 2008, 14:01 -
Is there a problem with my DVD Burner? Blank Disk after a Burn?
By nadizo in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 02:18 -
can't burn with sata dvd burner
By Shotobits in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2008, 14:53 -
DVD burner won't finish burn
By JDShaffer in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Jul 2007, 20:41
Statistics
Newest guides
Latest tool updates
New media comments
