Is there any way to connect a Motorola DCT6214 pvr to an DVD recorder via firewire...??? Has anyone done this...???
I've read an how to on connecting the Motorola to a PC via firewire and I know how to connect a DVD recorder via composite or s-video... But I'm curious if it can be done via firewire...
Both my Liteon 5005 recorder and Motorola 6214 pvr have firewire ports... According to the Motorola's setup firewire is enabled and is using firmware 10.10....
Any thoughts...????
Cheers
Kenmo
Results 1 to 9 of 9
I know I needed drivers for my XP box when I did this, so I would guess that the DVD Recorder wouldn't work.
But both of my DVD recorders... LiteOn 5005 and Toshiba DR2 have firewire in ports... Why would they need a driver...???
Here's how to connect to a WindowsXP pc...
http://replayguide.sourceforge.net/dct6412/
Here's a link... the poster claims he got his Cyberhome to record via firelink from a Motorola 6412...
http://www.satelliteguys.us/showthread.php?t=34908
No luck with either my Toshiba or Liteon...
I don't believe "bulldog" in those posts linked above. A DVD recorder's Firewire input is for DV video only. It doesn't accept the MPEG TS streams that are exported from the Motorola box via Firewire. The Motorola's Firewire link does work with JVC D-VHS recorders, which in turn can export the captured video via S-video to a DVD recorder.
This person claims MythTV supports recording to a PC via firewire... He also claims the Motorola outputs raw mpegII via firewire...
http://blog.vlad1.com/
Sorry to resurrect an old thread, but new software has made Windows Media Center capable of using a Motorola STB as a tuner with Windows Vista and upcoming Windows 7.
Take a look:
FireSTBPlugin
The original development can be found here.
Originally Posted by kenmoI thought of giving the Firewire -> DVDR route a try. Connected the Motorola 6416 firewire OUT to both, a LiteOn 5005 and Pio 650 Firewire DV IN from the left and right port. Didn't work with either DVDR. Even did a 'Cold Boot' on the Motorola box to download new software into the terminal with the Firwire plugged in, and a new initialization from the cableco. Although the Motorola 6416 Firewire port is enabled (as per Dignostic Menu), whatever digital signal is sent is not recognized by either DVDR.Originally Posted by Frobozz
If someone was ever able to get this going, please report the procedure used.
Problem: DVD-R Recording with Motorola QIP6416-2 DVR FiOS TV Box
By Plarocks in forum DVD & Blu-ray RecordersReplies: 12Last Post: 4th Jun 2010, 19:03 -
PVR HD to PC using FireWire ?
By wingfan in forum DVB / HDTVReplies: 7Last Post: 6th Oct 2008, 11:51 -
Problems creating DVD from Shaw Cable Motorola DCT64616 III transport strea
By Mendel in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 7th Feb 2008, 09:45 -
Capturing HD from Motorola 6412 via firewire
By z0diac in forum DVB / HDTVReplies: 1Last Post: 16th Jan 2008, 08:35 -
Motorola PVR to PC use of HDTVtoMPEG and HDTV2DVD
By brillmtb in forum DVB / HDTVReplies: 10Last Post: 18th Aug 2007, 21:44
