Haven't tried this yet, but a couple questions...
Is there any way to simulate the PSP connection, to allow the rendering, without actually having the PSP connected to the pc? I'd prefer to render the file(s) to the hard drive then manually copy them over. It seems silly to have the PSP connected during the transcoding, and I would hope that the transcoding is not writing out its progress to the memstick in the PSP.
Thanks!
Gary
Get a Memstick Pro --> memory stick adapter and put it in a USB card reader. It will read as a PSP connected.
you can render to a folder and copy it over later
Thanks for the replies. After reading a few other posts, but still not having tried the Export To PSP menu item, it seems that the Export To PSP is just an ehnanced version of the AVC rendering process, which will do the copy step for you.
I guess manually rendering to AVC in a folder should work fine, but I'll have to handle the file naming and thumbnail jpg/thm myself.
Thanks again!
Gary
PSP Test Clip: Need someone with a PSP to test for me!
By FulciLives in forum Portable VideoReplies: 5Last Post: 17th Feb 2009, 20:42 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 10:59 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 08:27 -
Nero 8 Recode to PSP - No Title on PSP?
By sonicm in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 14:13 -
Export to PSP - Vegas Studio Platinum
By narial in forum DVD RippingReplies: 1Last Post: 29th Jul 2007, 03:49
Statistics
Newest guides
Latest tool updates
New media comments
