So what is the Best and or fastest program for converting DVD's to avi/divx/xvid/etc.? I am using Fairuse right now but it is slow so I was wondering if there was one that is faster.
Thanks![]()
Do a forum search - this is asked regularly, and has been asked recently.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Waste of time and energy, leave them as mpeg2!Originally Posted by DungFubits
Why not just try a simple program like VirtualDub Mod and the Xivid/Divx codec? That would likely be the fastest as really all you have running is the codec. But the all-in-ones usually do more than just encode to AVI formats. There's framerate changes, audio conversions, change of resolution and a few more. These all take time.
A little more advanced program than Fairuse is AutoGK, probably a little faster. Also a little more to learn.
And Divx makes some conversion programs under their name.
Encoding speed is directly related to CPU speed. Using a faster CPU is where you will likely see the biggest speed improvement. Or you can reduce quality/bitrate and speed things up.
Myself, I would rather have more quality than speed.
AVISynth + VirtualDub (in fast recompress mode) + Xvid or Divx in single pass constant quality mode.
Nero Recode is fast too. But you'll end up with an MP4 file.
http://forum.videohelp.com/viewtopic...388992#1388992Originally Posted by DungFuIf in doubt, Google it.
What is the fastest program for DVD to avi conversion?
By danozard in forum DVD RippingReplies: 5Last Post: 13th Sep 2009, 02:54 -
The fastest way for converting a DVD into AVI
By Menvedao in forum Video ConversionReplies: 3Last Post: 23rd Jul 2009, 11:06 -
Fastest program to convert avi to dvd is to long
By goheadtry in forum Video ConversionReplies: 12Last Post: 27th Jan 2008, 04:33 -
What program gives the best quality results, when converting AVI/DIVX/XVID
By Rockstar452 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 01:19 -
Fastest AVI to DVD program
By mjaeson in forum Authoring (DVD)Replies: 16Last Post: 18th May 2007, 05:09
