I have a Comcast Motorola Dual-Tuner DVR High-Definition Set-Top DCT6412 and i'm trying to pull the data off it to my PC via Firewire. I've connected it to my PC and it has recognised a Tuner, AV panel, and one other unknown device, however, my computer was unable to locate drivers for such. (my system is a Dell 3.2 P4 HT processor, with 1024mb RAM, and a GeForce 6800 GT video card, running Windows XP Media Center). Is there a way to transer the the content across digitally so that i can edit out advertisements and store the content? If anyone has experience and could help me out with this i would greatly appreciate it. I've spoken to Comcast, and they do recognize that it is possible to do this, however, i was unable to get an explanation of how this is done. I visited the Motorola website and found no information or drivers. Any help would be greatly appreciated, otherwise i'm hookin my s-video to VCR and creating a new Tape collection.
Results 1 to 22 of 22
S-Video will get you there.
As for the IEEE-1394 port, don't expect this to be easy or even very usefull for what you want. MPeg2_TS streams are available for local channels only. Cable content is encrypted in most local areas.
Start here http://www.avsforum.com/avs-vb/showthread.php?t=403695 -
Read these instructions - pretty well documented.
http://replayguide.sourceforge.net/dct6412/
http://replayguide.sourceforge.net/dct6412/motorola6412_firewire.zip
EdDV speaketh truth, however. You'll be SOL on the encrypted stations. -
I'm not looking to record live streams, and, avoid having to do a real-time capture, that would be more effort than just hookin up the VCR, the shows i'm trying to record are black and white (Maverick w/ James Garner and Jack Kelly) so, pristine quality isnt a great issue, what i'm looking for is efficiency, if there is some way i can access the files on the DVR, and pull them to my PC as a file, then convert and burn, that would be my preference. However, the channel is from American Life TV, not local, but comcast has not given any indication that encryption is a problem.
Originally Posted by Xeviance
Encryption is on the IEEE-1394 port. For now you have to dub over S-video. -
Originally Posted by edDV
Second, you don't get HD video over S-video output.
Third, works great for me with 3412 box with Comcast. -
Originally Posted by MozartMan
True
Mileage varies locally. -
If you don't want real-time recording, then I got bad news for you. You still havee to record while you are playing the file.
The 5c flag is not limited to the digital channels. I had no problem transfering recordings to my pc but just a month and a half ago, Comcast here started flagging channels. Now I can't record any adult swim or CNN programs. I can still record OTA HD (except FOX) and the INHD channels.His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
So is there now way to add an external harddrive to the 6412 unit rented from comcast? There is the firewire port plus the usb port. I have found that the 120g hdd is just too small. I was hoping to add a second harddrive to help out is all.
Boy do I love my avatar! -
Originally Posted by Conquest10
Stop the broadcast flag!
http://www.eff.org/IP/Video/HDTV/
http://www.eff.org/IP/Video/HDTV/?f=broadcastflag.html
Write your Congress critter. -
Originally Posted by tsantsa
The only way I think you can try is using a DVD recorder to connect to the Comcast DVR output. After you record the show onto a DVD, you can rip the vid and edit it.
Originally Posted by tsantsaRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I have tried the method described below using the tools and drivers at replayguide.sourceforge.net and am able to capture the video but not the audio. At least there is no audio when I play the captured file. This occurs only when I am trying to capture a recorded program off of the DVR. When I record a show live everything works fine.
Also, when I start the record using the tool the screen freezes on the TV.
Does any one have any thoughts? -
I have a few non-premium channel programs on my comcast DVR box that I'd like to retain (daughter's birthday announcement on the local news, etc). The box is over 3 years old and in desperate need of an upgrade. I don't want to upgrade because comcast insists that they cannot copy anything over to the new box.
I am computer savvy, and can clearly see a Seagate 120GB hard drive through the air vents. After reading this thread, I gather that I cannot simply connect a male to male USB cable into the box and copy directly - so...
If i can get the box open without harming anything, would there be any problem with connecting the Seagate 120GB (via ribbonwire) to my pc as a slave drive, and directly copying files that way? I don't really care about encryption, as I should be able to reverse this and copy back to the new box when I get it. Though, a viewable digital copy would be ideal.
Seems i would need a special socket head. Has anyone successfully attempted this (or know where to obtain this tool)? Is it a good/bad idea to try? -
I don't think that would be possible - the drive isn't formatted in a way that can be read/seen by a PC as far as I know.
Go back up and read posts #2 and #3 - you should be able to get the content off the DVR to the PC following that info (I've done it a few times, most recently with "live" TV). I know of no way to return the content to the new DVR, but at least you'll have it saved.
Hope that helps. -
Thanks Jim, but i wonder about that. A file is a file... even if its hidden from windows, there are many ways to access an MFT. My only concern would be if it can plug-n-play
http://www.amazon.com/Lisle-26280-Master-Torx-Socket/dp/B0002NYBVO
Torx Sockets will do the trick on the screws. Any automotive store should carry them. -
Marcomarco - look at this thread:
https://www.videohelp.com/forum/archive/easiest-way-to-copy-file-from-comcast-dvr-t365905.html
Better question than are you computer savvy - are you LINUX/UNIX savvy? Gonna have BIG problems if the answer to that is "no" and you want to hook up the disk to your PC. And you'll still have to deal with encrypted media on the disk too. Comcast uses a Linux disk partition. The link I provided has a post by Cornucopia (one of our stronger technical members here) that tells basically how to play the video and capture it in real-time to a PC. Not really what you wanted, but it looks like a case of it being all you can do with the box. -
Yes, linux/unix savvy - but thanks for that thread. I might save some headaches and do just the capture.
getting recordings off comcast dvr
By Knightmessenger in forum CapturingReplies: 1Last Post: 15th Aug 2011, 19:34 -
My first post: connrccting a DVD to a comcast DVR to record from ther DVR
By retired_guy in forum Newbie / General discussionsReplies: 10Last Post: 24th Jul 2011, 19:54 -
Comcast DVR to DVD
By Beefer in forum MacReplies: 6Last Post: 2nd Aug 2010, 13:39 -
Moto DVR DCT3416 from Comcast - can I get the recordings off the DVR?
By jmkeuning in forum CapturingReplies: 42Last Post: 7th Jul 2010, 18:44 -
Record HD from a Comcast DVR?
By elister in forum DVB / IPTVReplies: 15Last Post: 10th Dec 2007, 18:11
