I reinstalled Windows recently and after that SVCD2DVD. I get an error message everytime I run it:
SVCD2DVD.EXE - COMMON LANGUAGE RUNTIME DEBUGGING SERVICES
Application has generated an exception that could not be handled.
Process id=0xa68 (2664), Thread id=0xa6c (2668)
Click OK to terminate the application.
Click CANCEL to debug the application.
Clicking either button does nothing. And after uninstalling and regcleaning the computer and then reinstalling...I get the same thing. Any help would be greatly appreciated as I dont wanna have to reinstall windows to fix this problem.
Thank You
JK
Thread: Debugging or similar error
Do you have .net framework1.1 and .net framework 1.1 SP1 installed?
I had Framework installed but not SP1 for it. I tried reopening the program and it didnt work still. I will uninstall and regclean and try again and post my results in a little bit!
PEACE
J_K
after sp1 i suspect a reinstall of SVCD2DVD is required: http://forum.videohelp.com/viewtopic...471652#1471652
Newbie debugging sync audio video problem
By siocnarf in forum Video ConversionReplies: 3Last Post: 24th Apr 2012, 20:42 -
On startup, keep getting a Common Language Runtime Debugging Services alert
By Carl III in forum ComputerReplies: 1Last Post: 18th May 2010, 16:04 -
Debugging coaster problem
By txporter in forum MediaReplies: 21Last Post: 29th Apr 2009, 05:43 -
Need timecode display movie for debugging
By cybertheque in forum CapturingReplies: 6Last Post: 23rd Oct 2008, 16:19 -
ffmpeg works only when debugging
By ariefimansantoso in forum ProgrammingReplies: 0Last Post: 21st Sep 2007, 07:05
Statistics
Newest guides
Latest tool updates
New media comments
