VideoHelp.com Forum
    I have two VIDEO-TS folders that I want to have on the same DVD disc. I also want to have a menu on the DVD so that I can select which of the two features I want to watch. I have searched around here on the forum and it seems as if this should be able to do in Sizzle e.g. I have tried this but it does not work, subtitles disappear for instance. Does anyone know if there is a simple way (or hard) to add two VIDEO_TS folders and add a menu?
  2. Member terryj's Avatar
    There is no simple way to do this when Subtitles are involved.
    If you have no need for Subtitles, You could try merging
    the main features and create rudimentary navigation
    via DVD2OneX's "JOIN" feature.
    But since subtitles are involved, the only way I've been
    able to do it is is to flatten and resave as .dv stream,
    using MPEGStreamclip,
    then re-create what I want using DVDStudio Pro.
    This way the subtitles are embedded in the video file,
    ( making then non selectable) and then I can create a menu
    and chapters to navigate the two features.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  1. Replies: 6
    Last Post: 29th Apr 2010, 14:37
  2. Replies: 11
    Last Post: 23rd Jan 2010, 17:10
  3. AVI to DVD not outputting Video_TS or Audio_TS folders
    By threesixes in forum ffmpegX general discussion
    Last Post: 30th Dec 2008, 01:23
  4. How do I rip DVD to VIDEO_TS/AUDIO_TS folders?
    By Crimea in forum Newbie / General discussions
    Last Post: 18th Feb 2008, 11:34
  5. how do install two folders video_ts in one dvd-r
    By togood in forum DVD Ripping
    Last Post: 13th Dec 2007, 05:58
