Help.
I unwittingly set up a new project in Premiere Pro as PAL, then captured the video and edited the footage and then encoded as m2v and wav file and realized that the video was a bit "choppy." I realized that I had not set up the project as NTSC. So without going back to square one and re-capturing and re-editing in a new NTSC project, is there a way to change the project settings to NTSC so that it will encode at 30 fps instead of 25? I'm stumped.
..is there a way to change the project settings to NTSC
Yes, but you'll take a hit in quality, and render time..
Basically, create a new project (the correct settings this time :P ), and go to File>Import>Project, and import the original Pal based project..
You should be able to drop this on the timeline..Unfortunately, it will need rerendering, so check for quality, and frameblending options before you go any further..
I'd personally start over again...
That'll teach ya...
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
Best format and method to upconvert and change ratio of video project?
By Joseph C. Krause in forum MacReplies: 4Last Post: 3rd May 2010, 04:35 -
Cannot Open Premiere Project
By Funky Monk in forum EditingReplies: 0Last Post: 29th Apr 2010, 02:47 -
Project Settings Window in DVD slideshow GUI
By tit4tat in forum Newbie / General discussionsReplies: 5Last Post: 3rd Mar 2009, 09:04 -
Premeire Settings for a 30p project
By Tfp in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 10th Jun 2008, 16:17
Statistics
Newest guides
Latest tool updates
New media comments
