I've got an .mkv file that i have, im attempting to convert it to dvd mpeg, and demux the subs, normally i would just run the mkv through virtualdubmod and demux everything, convert the video portion through tmpgenc or cce...or whatever else........but with this particular video, it came up with an error that i've never seen before...it said matroska stream 1 doesn't have a sample rate........i can still feed the video portion to tmpgenc, but i can't extract the subs.......anyone got any ideas on how i can either extract the subs or create new ones? the video is h.264 and the audio appears to be aac audio....
tried mkvextract?
Yeah, VirtualDubMod can only handle VfW video. It can't handle Native AVC and other newer mkv features. That's why there is a popup when you first run it warning that the mkv support is out of date. From recollection it even suggests mkvtoolnix which includes mkvextract.
awesome, thanks for the help...im good with divx, xvid, mpeg, ect....but im not very well versed with h.264.....seems to be a whole differant beast, at least till it's properly integrated with other programs....
Hi, Balrick. I've installed mktoolnix and am using mkextract to take the files out of mkv files. But whenever I do that, my audio and video are out of sinc (like, video 24 min, audio 21 min). Please, help.Originally Posted by Baldrick
the mkv could be vfr, variable frame rate...and I don't know any simple solution for that. see http://forum.videohelp.com/viewtopic...fr+mkv#1426652
Yeah, it is VFR. But I don't know how to do what Celtic Druit suggested. Should I extract the avi file, the convert it to m2v? But how to I get the different frame rate sections one by one?
Problem conserving 5.1 from MKV conversion
By l'ensemble in forum MacReplies: 1Last Post: 24th Jan 2011, 14:35 -
Problem on MKV Conversion. Please help.
By maicans in forum Video ConversionReplies: 2Last Post: 11th Jun 2010, 11:17 -
Problem with mkv to DVD conversion
By LoafingOaf in forum ffmpegX general discussionReplies: 0Last Post: 27th Oct 2009, 06:46 -
.ts to mkv conversion problem
By txl in forum Blu-ray RippingReplies: 1Last Post: 15th Sep 2009, 05:19 -
aimersoft mkv conversion problem...
By freewheelin in forum Video ConversionReplies: 1Last Post: 6th Sep 2009, 13:22
