Hi:
I have this problem: If I use ffmpegX´s GUI I can process a file OK. If I want to do it using the terminal I get an error stating that the input file doesn´t have any video or audio streams.
I´d like to find out the exact command ffmpegX is sending so I can try to do the same in the terminal.
I really like ffmpegX, but I need to command the encoder from an AppleScript.
Is this possible?
Thanks a lot.
JP
Results 1 to 1 of 1
Anyone Can Help to Convert This Preset to FFmpeg Command Line?
By raymng in forum Video ConversionReplies: 2Last Post: 26th Feb 2012, 12:11 -
Paid Job - Convert Preset Files to FFmpeg Command Lines
By raymng in forum ProgrammingReplies: 0Last Post: 19th Feb 2012, 03:01 -
using the dd command in terminal to backup DVDs
By redishdog in forum MacReplies: 10Last Post: 24th Nov 2010, 19:46 -
Autodesk Wiretap Central (ffmpeg based) 4:1 issue
By Motawm in forum Video ConversionReplies: 2Last Post: 26th Oct 2009, 05:22 -
Windows Media Encoder based application deployment issue
By George2 in forum ProgrammingReplies: 0Last Post: 12th Jul 2009, 05:19
