VideoHelp.com Forum
    well
    i have my own user
    which i cant install anything with it
    so how can get through this
    or change it as ADMIN , so i can unstall it
  2. Member Faustus's Avatar
    Click on start then select either Log Out or if thats not there SHut down THEN select log out. You SHOULD be able to login as administrator at that point with the password you setup.
    If Admin isn't an option you may want to turn off the graphical login inside Control Panel.
    Just take a word of advice and make double sure you know all the actual logins and passwords for the machine before you mess with anything. I'd hate to see you get locked out.
  3. Member Treebeard's Avatar
    you can boot in safe mode and this will allow you to log in as admin. once there I would change your own user name privelages to full so you can install under your own user name.
    well
    its not that easy
    i just wanna install soem softwares
    and i cant
    the a** h***s , they wont let even change the screen saver timer
    even when i go save mode, it asks me for password
    any other way?
  5. Member Faustus's Avatar
    ysfm is this not your personal machine?
  6. VH Veteran jimmalenko's Avatar
    Almost sounds like group policy restricting you. Better talk to your IT guys
    Incidently, I found a boot CD image today via google that allows you to reset / blank / change the local administrator password. Absolutely brilliant !
    http://www.petri.co.il/forgot_admini...r_password.htm
    http://home.eunet.no/~pnordahl/ntpasswd/cd050303.zip
    If in doubt, Google it.
    Originally Posted by jimmalenko
    http://www.petri.co.il/forgot_administrator_password.htm
    I've used this on an XP machine where the Admin password had been set by the retailer so you had to go back to him if you wanted to change anything. Ran it as a last resort and it simply removes the password so you don't need to enter one. Definitely works and doesn't affect anything else.
  1. Need Admin Help!
    By Husk3r in forum Feedback
    Last Post: 17th Feb 2009, 15:59
  2. Help with pc admin properties
    By SIRCOOKS in forum Computer
    Last Post: 29th May 2008, 17:54
  3. Remote PC Admin Control?
    By Xenogear900 in forum Computer
    Last Post: 11th Oct 2007, 08:35
  4. Installing on a NON-Admin account?
    By mamefan in forum ffmpegX general discussion
    Last Post: 27th Jun 2007, 11:47
