I've got a problem with PVR usb mpeg2 capture off of old video. Approx 1/8" left and 3/16" bottom needs to be trimmed. Bottom 3/16" is distortion, left 1/8" is black bar. This is viewed in full screen mode, 480 x 320 capture rez. Any trim tools out there? Or is it a setup problem? Device: Hauppauge PVR USB 941, capturing 12.0 mbps, full D1, off of a feed from JVC hrs9500u, thru JVC edit board.
You must reencode the video if you need to crop it. Use for example tmpgenc.
and read http://www.digitalfaq.com/dvdguides/...tandsource.htm
Noise around the edges.
By MaiOns in forum Newbie / General discussionsReplies: 8Last Post: 14th Mar 2010, 10:52 -
easiest way to trim captures ?
By Tafflad in forum CapturingReplies: 8Last Post: 14th Feb 2010, 14:24 -
Trim start and end of MPEG2 compliant video.
By mattstan in forum EditingReplies: 5Last Post: 25th Feb 2008, 10:06 -
Do DVD resolution mpeg2 captures require to be encoded ?
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2007, 17:08 -
How to cut/trim HD-MPEG2 without encoding?
By edong in forum Camcorders (DV/HDV/AVCHD)Replies: 8Last Post: 27th May 2007, 17:50
Statistics
Newest guides
Latest tool updates
New media comments
