Is there something similar to DVD Shrink for a MAC?
Results 1 to 9 of 9
Thread: DVD Shrink for Mac
SGHOGAN
DVD Remaster is also excellent.
Popcorn - compress and burn, ~ $40
Toast - compress and burn, and more, ~ $80
DVD2One - compress and burn, ~ $60
DVD Remaster - compress only, ~ $40
FastDVDCopy - compress and burn, ~ $80
DragonFlix - compress and burn, ~ $40
Thanks to everyone for the responses
SGHOGAN
What about the most important part about DVDShrink which is that it's freeOriginally Posted by macuser25
I was hopeing for something free but it looks like that won't be the case for a mac.
SGHOGAN
Shrinky-DVD-ink has an interface similar to DVD Shrink
www.shrinky-dvd-ink.com
A not-free, but inexpensive, option is ffmpegx. Once you've paid your registration fee, you can gain access to its shrink tool. I've never used it, and it looks very basic, but it should get the job done if you only care about preserving the main title. If you need to do a lot of complex reauthoring, then you'll need to use something else. But for a basic "shrink the main feature to fit on a DVD5" task, ffmpegx should work.
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 05:04 -
'DVD Shrink' for Mac?
By SilverBlade in forum MacReplies: 13Last Post: 3rd Nov 2010, 18:36 -
im new to mac... is there a mac program that does what tmpgenc dvd author 4
By ochsfamily in forum MacReplies: 0Last Post: 12th Dec 2009, 22:13 -
Using a Mac...DVD Shrink
By richard_m_morales in forum MacReplies: 10Last Post: 7th Dec 2009, 01:43 -
How to Shrink 7.7 GB VOB files to 4.7GB DVD on MAC?
By mc80 in forum MacReplies: 5Last Post: 30th Mar 2008, 09:41
