VideoHelp.com Forum
  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Just downloaded VLC media player. Unzipped it and tried to use it but nothing works. Tried to opn the VLC.exe and nada? Anyone guess why, or how to get it to work?
    What We Do In Life, Echoes In Eternity....
  2. Member Krispy Kritter's Avatar
    If you download the exe version, it will self install. I would imagine that with the zip version, you have to unzip and then install it. You can't just unzip and run it.
    Google is your Friend
  3. [url=http]text[/url] Denvers Dawgs's Avatar
    When I unzipped all there was, was the exe file anbd a bunch of .dll's and plug-ins no Installer? Clikcing the exe did nothing....I guess I'll try the self install download...
  4. Member Faustus's Avatar
    Make sure you have the .exe linked on the front page.
    Should be named "vlc-0.8.4a-win32.exe" it should have no other files with it.
    When you double click on that file it doesn't popup and ask you to selete a language?
    The default installer shouldn't be zipped to begin with.
  1. Replies: 6
    Last Post: 20th Mar 2012, 10:22
  2. display size between windows media player and VLC player
    By kool_k in forum Software Playing
    Last Post: 6th Aug 2011, 15:18
  3. VLC Video Player won't open subtitles
    By snafubaby in forum Software Playing
    Last Post: 14th May 2011, 22:47
  4. Replies: 9
    Last Post: 22nd Aug 2009, 18:06
  5. VLC Media Player
    By Flying Doctor in forum Video Conversion
    Last Post: 26th Jun 2007, 09:38
